Murnan Modified Motors
#2011
#2012
What are you guys running for plugs in the 12+3mmm?
I've always had good luck with RB-5 in other nova's. Have dozen left.
Grinder whats your recomendation? There is so many different letter codes in nova plugs.
#2013
You can run the RB #5 plugs no problem. We normally run Novarossi #6, sometimes #5's. Sometimes #7's too. They will all work, they will just require a little different tune.
#2014
also if you will be using nova plugs go with the ultra plug series( the ones that are black) they are great and last longer too
#2015
Thanks guys. Does anyone understand the letter codes in nova plugs?
#2017
Sorry, another stupid question.
I am very keen to try the MM motors but I don't know which to pick. I currently run the .12OS TZ 3 and 5 port on my NT1.
Does anyone has any recommendations on what I should upgrade to?
#2018
The nova's tune easyer. I think its a better carb. But pricey.
The picco can drive a person crazy getting it tuned right. But it makes good power at an attactive price.
#2021
help with nova sct.12 murnan mod
Uriah need help i just bought a mm nova .12sct what fuel do you think i should run and at what % also would i need any head shims or is it ready to go after you modifed it thanks
#2022
I just did this with uriah. If you didn't ask for it to be shimmed for a specific nitro percentage then its as shimmed from the factory for 16% nitro. A couple of pages back on this thread there is head shimming instructions. I am going to run 20% with my 12-3sct with the stock shim package.
#2023
HELLO URIAH, O RECENT BUY TWO NOVAROSSI 353 MODIFIED WITH ALL CERAMIC BEARING FROM TORY SANTIAGO (PR DISTRIB), I NOTICE THAT COME WITH SPARE LOW NEEDLE MUCH LONGER, I WANT TO KNOW WHAT IS THE DIFERENCE WITH THE ORIGINAL?
THANKS,
DANIEL MAZZARA
THANKS,
DANIEL MAZZARA
#2024
Hi. The short needle will give you a smoother powerband with less fuel consumption. The blunt needle will be more aggressive, and drink more fuel. There is also another fuel inlet nipple for the carb that is bigger, that will of course will add power at the expense of fuel consumption.
#2025
Personally I use Rocket Science fuel, I feel it offers the best protection against wearing out the engine internals. Although it is a little more difficult to break in an engine using Rocket Science.
