Old 10-13-2008, 12:44 PM   #1981
Grinder's Avatar
Originally Posted by ToysRUsKid View Post
Anyone using that pressure line regulator? Just curious about how it helps performance.
The regulator takes some time to get tuned in, but it does help runtime without hurting the performance too much.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 10-13-2008, 12:44 PM   #1982
Grinder's Avatar
Originally Posted by sm1nts2escape View Post
Well today I put a good clutch clutch on the car with the oval restrictor and went to 17/49 21/47.After almost a full gallon I started tunning her up alittle.I am very impressed.Think I am going to end up running a 7mm restrictor for 5 minute runs.This motor has soo much torque.It pulls so hard down the straight it is almost too muchAfter I got her tuned up decent I was running some laps and slammed the throttle hard coming out of a turn just like I normally do and the car spun out.I tryed to get back on the throttle and it spun out again.Got the car back in the pits and to my amazement I broke another rear axle.I have never had this happen before till I put this motor in my car.I broke my first axle last week when I ran two hot tanks and completely snapped one today.I have never had that happen before or seen it before on a mrx.The right rear axle went first then today the left rear axle went.One was a gallon old and the other was the original.I also stripped my front belt and rear belt which ended my day.I guess I am going to have to loosen the clutch alittle and be alittle more careful with my throttle finger.I am amazed by the power this thing has now.Will definitely do more buisiness with you.Thanks for the grin.
Old 10-13-2008, 03:17 PM   #1983
JetMD's Avatar
Do you have any advice on using the regulator? I tried it on my motor and a friend's motor and they would not run right with it. It doesn't come with any tips on use. It just says where to set it initially and tells you to go 2 turns richer on the top end needle. I'm not running it anymore but would like to when I need that extra mileage.
Plus, it's a kinda expensive paper-weight.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 10-13-2008, 03:32 PM   #1984
wingracer's Avatar
Trader Rating: 22 (100%+)
If you can't figure it out I wouldn't mind trying it out.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-13-2008, 04:10 PM   #1985
GMartinez's Avatar
Trader Rating: 84 (100%+)
Uriah Thanks for all the help @ the Sedan Nat's
See ya @ the Winter Nat's
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is offline   Reply With Quote
Old 10-14-2008, 06:29 AM   #1986
Big Jeff BBQ's Avatar
Uriah thanks for the hard work in the pits for the Masters A main Fuel sedan
Nationals.
later
Jeff E
Good luck at the 95 Showdown!
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 10-14-2008, 07:46 AM   #1987
JetMD's Avatar
I'll be at 301 this weekend and Vorra the weekend after. You are more than welcome to give it a shot Sean. I'll be there with Kevin, Rick, and maybe Craig.
www.vorra.org
MINO Racing
Old 10-20-2008, 10:55 AM   #1988
Grinder's Avatar
Default New Capricorn Pricing
We are now able to offer a lower price on all of the Capricorn RC hopups.
http://www.murnanmodified.com/index....0fa794c89135e3
Old 10-21-2008, 04:57 AM   #1989
Uriah, this new Capricorn main shaft for the RRR is lighter than the original?
V1RRR Evo WCTE - Sirio STI/NR 353 MM - Futaba 3PM FASST
FW05TRR - GXR15 Tunned - Futaba 3PM FS Pro
Ramiel is offline   Reply With Quote
Old 10-21-2008, 10:01 AM   #1990
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
whats up URIAH good seeing you frank & big jeff at nats take care
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 10-21-2008, 10:43 AM   #1991
freestyles's Avatar
Trader Rating: 14 (100%+)
can someone tell me the benefits of using the Monolith Brake Disk for NT1 that's on the website? I'm thinking of replacing the NT1 brake pad & disk so I'm looking at the Kyosho V-One RRR pads but not sure which disk.
K factory make a nice set of after market pads and vented brake discs for the TM G4 and i think the RRR. They call them "real racing brake pads" because they have real cars brake pad material and are very strong, no fade and look sweet.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 10-21-2008, 11:49 AM   #1992
i use the monlith brake disc and km factory brake pads for the mtx4 ...no brake fade watso ever....they also make them for the nt1
pballer10 is offline   Reply With Quote
Old 10-21-2008, 12:36 PM   #1993
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
I will try the k-factory pads, I didn't know they had any for the NT1. I have the exceed disk which works really well but my stock pads are severely worn and I tried the Kyosho pads but they don't fit.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 10-21-2008, 01:08 PM   #1994
im not sure i can post a linkof website but its not the k factory brake pads
Old 10-21-2008, 03:41 PM   #1995
GMartinez's Avatar
Way lighter than stock & very strong
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
