Old 06-13-2008, 07:17 AM   #1786
itchy b's Avatar
Originally Posted by aussies1129 View Post
Hi Guys are you able to mod a picco tune engine?
thanks
I believe that you are after the Murnan Mod Tune JLR!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 06-13-2008, 07:50 AM   #1787
Originally Posted by ira View Post
The Byron Fuel is great, just make sure you have the correct head shimming.
OK, maybe I shouldnt use it because I have no idea what your talking about, what does that mean and is it easy to do
rcjayy is offline   Reply With Quote
Old 06-13-2008, 07:54 AM   #1788
wingracer's Avatar
Trader Rating: 23 (100%+)
Is that a .12 or a .21? In my experience .21's run fine on 30% with stock head clearence. .12's you may want to add a head shim. It's very easy to do.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-13-2008, 08:02 AM   #1789
its a .12, so im gathering that the piston and sleeve needs more clearance with the 30% and you add a shim for more space?
Old 06-13-2008, 09:24 PM   #1790
Hi,
Just a quick question Uriah, I purchased your RBR3 MM..Can I run 25% on it?
Also best Plug to run it on ?
CrazyJoe is offline   Reply With Quote
Old 06-13-2008, 11:08 PM   #1791
Hi,
what is the best pipe for +12-3SCT for long and short track ?
coideloko is offline   Reply With Quote
Old 06-14-2008, 04:32 AM   #1792
Grinder's Avatar
Originally Posted by coideloko View Post
Hi,
I use the 2630 with short header for long tracks. The 2604 RB with short header also works great on large tracks. I usually just change the header to a long, or medium if the track gets really small. The 2604 gets a little better mileage than the 2630, and still makes great power.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 06-14-2008, 04:35 AM   #1793
Grinder's Avatar
Originally Posted by CrazyJoe View Post
Hi,
You can run 25%, but you should add .2mm of head shims before you really step on it. The best plug for power is the #5 turbo. We usually can get away with #6 Turbo for racing. It is a good compromise between power, and mileage.
Old 06-14-2008, 04:41 AM   #1794
Grinder's Avatar
Hi. You should add a .1mm shim to run 30% in the Sirio. Just remove the 4 head bolts, then remove the cooling head. The head button should slide right out. Underneath the head button you will find an assortment of shims. That is the point where you add/remove head shims.
Old 06-14-2008, 04:43 AM   #1795
Grinder's Avatar
Originally Posted by AddictedToRacin View Post
Uriah, do you modify the new orion engines?
Just won a race with your modified old one though.
Soon enough I will test the new Orion engines. Stay tuned. From what I hear they run more like a conventional "engine" meaning they make more low end torque than the past model.
Old 06-14-2008, 12:58 PM   #1796
AddictedToRacin's Avatar
Yeah, they make definitely more torque than the old ones but I think they have not the same rpm.
Please let me know if you can modify one because I would want to send one to you.
AddictedToRacin is offline   Reply With Quote
Old 06-14-2008, 06:59 PM   #1797
Thanks grinder, should I add a 1mm shim to whats already their or remove whats their and add the 1mm shim also what glow plug do you recommend for the sirio III sti and should it be warm or hot
Thanks again grinder
Old 06-14-2008, 07:47 PM   #1798
wingracer's Avatar
Add a .1mm shim. That's "point" one, not a full 1mm. And yes, add it to the ones there.
Team Shepherd USA
Old 06-14-2008, 08:27 PM   #1799
aussies1129's Avatar
Trader Rating: 74 (100%+)
I bought the tune version and wonder if its worth getting modded?I also have the evo3 which I want to get modded also?
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 06-18-2008, 09:46 PM   #1800
JetMD's Avatar
Uriah, you have PM. Please help!
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
