Old 11-07-2003, 09:09 AM   #166
serpentracer1's Avatar
Send a message via AIM to serpentracer1
Just want to let you know I picked up one of your motors from Lee at winners circle,Your motor kicks AZZ.Great work on it looking forword to running more of your motors
DAVE (THE SNAKE) Rasnake
Original Mimi Wong Clan. M.W.C. For Life
Losi 22/Losi 8ight
Orion R10 Pro VST powered
serpentracer1 is offline   Reply With Quote
Old 11-07-2003, 09:13 AM   #167
JJ187RC's Avatar
Next dumb question,
What do you have to do to run a turbo plug in a non turbo engine?
serpentracer1, you won't be dissappointed, I had him do a rossi pixy black for me and the engine runs very well and is easy to tune when weather changes occur.
JJ187RC is offline   Reply With Quote
Old 11-07-2003, 09:19 AM   #168
Oh im not just got back into nitro after a 4yr layoff and getting used to tuning the motor myself I used to have a motor tuner before all I did was chassis setup so im getting used to it and the thing is flying
Losi 22/Losi 8ight
Old 11-07-2003, 09:54 AM   #169
EdwardN's Avatar
Default Re: ROAR Rule Changes
Originally posted by JJ187RC
Grinder,
Just found out that Turbo plugs are going to be allowed for all nitro classes in 2004. I think for .12 touring, the limit is still 3 ports. The question I have is do you see any advantage running a turbo plug versus a non turbo plug with the type of modding you do on the engines or any engine in general?
Because of turbo plug design ( will not go to details), turbo plugs are much better then regular on any type of engines. This advantage is easy visible if right tunning is done ( not modding-tunning). So you can use turbo plug every where and should have at list 5-8% of power gain easy ( in some cases was indicated +15 %).
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 11-07-2003, 10:04 AM   #170
InitialD's Avatar
Change the non-turbo button head to a button head that fits a turbo plug?
Old 11-07-2003, 10:05 AM   #171
EdwardN's Avatar
Next dumb question,
To use turbo plug on non turbo engine, you need first replace regular head botton to turbo head botton and then make sure to use advantage of turbo plug right-you will see difference right away.
Old 11-07-2003, 10:40 AM   #172
spenzalii's Avatar
Send a message via AIM to spenzalii
Just out of shear curiosity, do you do any mod work on OS motors, Grinder? I may pick up one of your Sirios, but I may keep my OS as a fun knockaround motor.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 11-27-2003, 03:03 PM   #173
Grinder's Avatar
Wink Murnan Modified Sirio Evo II
Modified Sirio Evo II Crank
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 11-27-2003, 03:05 PM   #174
Grinder's Avatar
Murnan Modified Sirio Evo II Aluminum Sleeve
Old 11-27-2003, 04:10 PM   #175
stefan's Avatar
Send a message via AIM to stefan
Uriah,
is that crank scoop supposed to be ROAR legal?
stefan is offline   Reply With Quote
Old 11-27-2003, 04:19 PM   #176
Originally posted by stefan
Uriah,
For sure not Efra. IFmar sould release the update rules about engines soon. Donīt know exactly the ROAR rules, i think that as long as the internal crack hole has the same diameter, is roar legal
Paolo M is offline   Reply With Quote
Old 11-27-2003, 04:21 PM   #177
Default Re: Murnan Modified Sirio Evo II
Nice work Uriah
Did you try already to work in the exhaust port on the allu sleeves? Seems that the chrome in the allu sleeves is more sensitive to the diamond tool than the brass one
Old 11-27-2003, 06:29 PM   #178
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
what is the murnan mod. web site?
mtx3racer is offline   Reply With Quote
Old 11-27-2003, 06:37 PM   #179
B
i believe it is www.murnanmodified.5u.com
try it
B is offline   Reply With Quote
Old 11-27-2003, 06:40 PM   #180
afm
afm's Avatar
Hi Grinder
This a better forum to talk about Sirios. By the way my Sirio pipe should arrive this Monday, I'll test it and let you know my impressions.
Two questions:
Head shiming: The Sirio Evo 2 measured cylinder recess from piston at top PMS and got 2.45mm, measured head recess and got 2.00mm, so we have a difference of .45mm.
To use the engine with 20 - 25% nitro, what is the ideal total chamber one should have? I've read that it should be around .55mm, is this correct?, because the engine comes stock with two copper shims, one is .10mm and the other is .15mm, so i could just use the .15mm, am i right?
Glow plugs: What is the equivalent of O'Donnells 77 and 99 on Novarossi??, because that is what is available down here.
AFM
afm is offline   Reply With Quote
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 01:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 03:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 09:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 09:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-20-2004 12:01 AM
SEO by vBSEO 3.5.0
