Old 04-30-2008, 07:51 AM   #1726
ctsieber's Avatar
Originally Posted by el greco View Post
Hello
Someone nows hoo is Uriah?
He doesn t answer my mails.
I need a Mod Picco p9r engine
Best regards
Theo
http://www.murnanmodified.com/produc...roducts_id=278
you can order it right from the website
ctsieber is offline   Reply With Quote
Old 05-01-2008, 01:15 PM   #1727
MTX4JR's Avatar
Uriah do you still stock modified parts for the novarossi ll3 and also what pipe do you recomend. Application the miami home stead track. Thanks the look of the new site is great.
Either go Fast or go Home.
Car: Mtx4
Radio Futaba 3pk
Engine: Novarossi / Os Speed Tunned.
Fuel: Maxy / O' Donnell
MTX4JR is offline   Reply With Quote
Old 05-05-2008, 12:30 PM   #1728
StewartFan20's Avatar
How often should ceramic bearings replaced? Do they last longer than steel?
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 05-05-2008, 01:52 PM   #1729
ma racer's Avatar
Any dyno results from the RB Alpha's? THX from Houston.
ma racer is offline   Reply With Quote
Old 05-06-2008, 07:12 AM   #1730
Big Jeff BBQ's Avatar
duno about the dyno !
But i seen it at the Sugar Bowl sunday and it sure spooled up very Quick!
looked superfast to me and a sound of it's own!
later
Jeff E.
I'm sure Uriah will speak for it soon!
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 05-06-2008, 08:50 AM   #1731
Maximo's Avatar
I would like to see some dyno results too.....if you got em you might as well show em... I have yet to see any real dyno results from a Murman Engine.... If you got the power lets see it !!!!!!
Maximo is offline   Reply With Quote
Old 05-06-2008, 01:30 PM   #1732
Grinder's Avatar
Hi. I do not have parts for the LL3 anymore. I recommend the Novarossi 2630 for that engine.
Grinder is offline   Reply With Quote
Old 05-06-2008, 01:33 PM   #1733
Grinder's Avatar
Hi. Ceramic bearings last longer than steel if they are good quality bearings. They should be replaced when they start feel gritty, or have too much lateral play. You can often hear when the bearings are going bad. You will hear a rattling metallic sound.
Old 05-06-2008, 01:44 PM   #1734
Grinder's Avatar
Here you go.
The #'s may be hard to read so they are as follows
Stock Alpha
HP= 2.30
Torque = 74.33 Oz in
Modified Alpha
HP = 2.44
Torque = 81.38 Oz in
The Alpha can be made faster, but the tendency is for the aluminum sleeve to break, and ease of tune goes away. This has shown to be a good compromise between power, and reliability on the modified Xenon Alpha.
Old 05-06-2008, 01:48 PM   #1735
Grinder's Avatar
Not sure why the images are not showing up too well. I will try again. Here is the Murnan Modified 35+21 vs Stock 35+21 graph.
Stock 35+21
HP = 2.50
Tq = 79.18
MM35+21
HP = 2.85
Tq = 81.38
Old 05-06-2008, 01:53 PM   #1736
Grinder's Avatar
The images were too big. These are easier to see.
Stock Alpha
HP= 2.30
Modified Alpha
HP = 2.44
Old 05-06-2008, 01:54 PM   #1737
Grinder's Avatar
Stock 35+21
HP = 2.50
Tq = 79.18
MM35+21
HP = 2.85
Tq = 81.38
Old 05-06-2008, 02:16 PM   #1738
quietstorm76's Avatar
Hey Grinder can you post results for the Picco P9R stock and Modded?
I know your results are not for show but I can't afford either of the above two engines so I'm just curious.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 05-07-2008, 04:58 AM   #1739
RayJ's Avatar
Hey Uriah,
I was wondering if you know this one. I was looking at the part numbers for the piston, sleeve and rod for the N12LS3 as part number 08672. I'm looking to get a replacement set for my MAX SL3 and Max lists it as MX08672. Do you know if they are indeed the same? I know the bore and stroke of the motor are the same. I know the sleeve for the the max motor is longer than the typical NS series motors when Novarossi changed the crankcase. Was this the case also with the N12LS3 motors? I'm interested in buying it if it will work. I know the rod is the standard 07601 rod.
RayJ is offline   Reply With Quote
Old 05-07-2008, 06:09 AM   #1740
What is the best way to change bearings? Are there any tools available to help?
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
