Old 04-14-2008, 07:28 PM   #1711
GMartinez's Avatar
Trader Rating: 83 (100%+)
Uriah Thanks again for providing me with an engine @ short notice to run when my beering went south like I said I could not make it to the semi's without you.See ya @ the Classic
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is offline   Reply With Quote
Old 04-15-2008, 04:25 AM   #1712
Grinder's Avatar
Originally Posted by NinjaRacer View Post
Gringer; What would be the performance advantages/disavantages of the Reddot Evo3 with the Skyline VR12+ and the Picco 2607 pipes?
The Skyline will let the engine rev a little higher. The 2607 makes gobs of power, and torque but can seem to go flat on the larger tracks. The Skyline does not.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 04-15-2008, 04:27 AM   #1713
Grinder's Avatar
Originally Posted by advfuel View Post
Grinder, why is the sky blue
lol:
Old 04-15-2008, 09:05 AM   #1714
ctsieber's Avatar
Originally Posted by Grinder View Post
lol:
ctsieber is offline   Reply With Quote
Old 04-18-2008, 08:07 PM   #1715
Default Sirio Power Clutch
Just wanted to thank Murnan for sending out the sirio power clutch so quickly. Ordered it late evening April 17. Got it today on the 19th. Now, that's what I call FAST SHIPPING ( GA. to CAL.) .
Zac Project is offline   Reply With Quote
Old 04-18-2008, 09:27 PM   #1716
Hi Murnan
What differences did you find between the Max Power 2602 pipe and novarossi 2630 with 6 fin medium header on the Nova Plus2 353 engine? And please advise which pipe is better suited to small, medium and large track with the 353 engine? Thanks!
air jordan is offline   Reply With Quote
Old 04-26-2008, 07:30 AM   #1717
Hey Uriah, I have a Sirio Evo2 3 port AAC. Are there parts still available for this engine? Or can I use EVO 3 internals? Are there any other internals that might work with this engine? Thanks!
Baedarlboo is offline   Reply With Quote
Old 04-26-2008, 07:58 AM   #1718
racingboy14's Avatar
Trader Rating: 25 (96%+)
murnan, do you port prebroken in engines? Do you mod .21 onroad rb motors?
Bk Graphics Custom Painted Bodies
Email me at bkessie@woh.rr.com for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline   Reply With Quote
Old 04-26-2008, 02:17 PM   #1719
Default PM
Racingboy14 You Have PM
dfilo456 is offline   Reply With Quote
Old 04-26-2008, 05:46 PM   #1720
Grinder
i have been running in one of your 2008 353 and on the last 750cc on your break-in it is running at 125 degrees Celsius "257 F" running on 16% nitro 12% Castor with a extra .1 shim on the head.
could it be the motor is still to tight cold or could a early clutch and 2 speed be causing the heat in the motor. the motor is really rich.
what is the purpose of the other needle that came with the motor.
Peter
The_Keeper is offline   Reply With Quote
Old 04-28-2008, 11:31 AM   #1721
Grinder's Avatar
Originally Posted by air jordan View Post
Hi Murnan
The 2602 will give you a little more out of the hole than the 2630. The 2630 will rev more. I would go with the 2602 on a small track, and the 2630 on a larger track.
Old 04-28-2008, 11:50 AM   #1722
Grinder's Avatar
As far as I know there are not parts made for that engine. I think that the Evo 3 parts do fit in the Evo 2. You would have to use the Evo 3 crank, rod, piston, sleeve, pin, etc..
At any rate you are better, and cheaper to get a new Sirio Evo 4.
Old 04-28-2008, 12:00 PM   #1723
Grinder's Avatar
Originally Posted by The_Keeper View Post
Grinder
Peter
Hi. The engines are very tight when new. Those temperatures are not a problem as long as your still rich. The engines run optimally around 280 F sometimes hotter. You will also typically want to remove the extra shim after break in if you are running 16% nitro.
The clutch, and 2 speed can cause some heat if they engage too early. It is more likely that those are normal operating temperatures. Also the more you lean the engine the faster the car goes the more air cools the engine. Many times I can lean my engine, and the temps will remain the same due to the increased airflow.
The other low speed needle valve will smooth out the throttle response, and give you better fuel mileage.
Which pipe, and header are you using?
Old 04-28-2008, 01:56 PM   #1724
Thanks Uriah!
Old 04-30-2008, 03:58 AM   #1725
Default p9r
Hello
Someone nows hoo is Uriah?
He doesn t answer my mails.
I need a Mod Picco p9r engine
Best regards
Theo
el greco is offline   Reply With Quote
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
