Old 04-07-2008, 11:02 AM   #1696
bugnet's Avatar
Originally Posted by ctsieber View Post
Bugnet,
I will say this, the +12 took alot more break in then any other motor I've owned. So expect afew more tanks for break in.
My MM 353 is just in their 18 fuel tank, still with stock plug C5 and 2630, going 6+min on local tight but not really small track (14~16s/lap) full of 180 turns, I think I should go to 2601 pipe and get more fuel mileage and torque, and try not to loose awesome top-end rpms, and after more two tanks I would change to C6 or C7 plug too.
Ir ur coming bring me some
bugnet is offline   Reply With Quote
Old 04-09-2008, 08:31 AM   #1697
JetMD's Avatar
Ran my Murnan Plus 12 with a Max 2607 pipe for the first time on the track yesterday. Saying I was impressed wouldn't be saying enough. The motor has bottom end like i've never seen. Running 38 tires and a conservative clutch setting, if I squeezed the trigger, the tires were spinning all over the place. The motor pulls down the big straight at 301 raceway with no problem at all. And runtime is amazing. Didn't check it but i'm sure it's over 5min. I kept thinking, "Man, when will it run out?"
Incredible. Thanks Murnan.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 04-09-2008, 08:43 AM   #1698
What is the recommend manifold and pipe combo for the RB R3? It will be going in a NT1 fairly large track 180-220ft straight. Also who has them in stock need to order asap....Thanks!
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 04-09-2008, 08:56 AM   #1699
Send a message via AIM to jeff whiting
Grinder, could tell us which Temp Gun you recommend?
JEFF
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 04-09-2008, 12:14 PM   #1700
rankev11's Avatar
Grinder, how do you know when a rear ceramic bearing is bad? I have a Murnan +12sct that make a noise a little louder than the exhaust at idle. I see nothing wrong with the p/s/r and it will idle through a full tank without cutting off. The front bearing has a little slop side to side but rolls smooth. The rear ceramic bearing looks ok and feels smooth when spinning the crank by hand mostly but there is a slight rough spot every once in awhile. Should I replace them with the new part # bearings in the 353? Are they any better designed? Thanks for your time and input.
rankev11 is offline   Reply With Quote
Old 04-09-2008, 12:29 PM   #1701
Did you check the thrust and the centax bearings?
V1RRR Evo WCTE - Sirio STI/NR 353 MM - Futaba 3PM FASST
FW05TRR - GXR15 Tunned - Futaba 3PM FS Pro
Ramiel is offline   Reply With Quote
Old 04-09-2008, 01:05 PM   #1702
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
If it sounds like you have chain drive car then its the bearing.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 04-09-2008, 01:18 PM   #1703
rankev11's Avatar
Sorry, forgot to say it was on the break-in bench. I figure it is a bearing but I am trying to eliminate on or the other since the rear is about $100 to replace. This is my first engine with ceramic bearing so I was just wondering how quickly they go bad. I may just replace the front and put it back together and see if it still makes the noise.
Old 04-10-2008, 12:40 AM   #1704
Grinder's Avatar
The engine may sound like metal to metal a little when it is brand new. After the engine gets warmed up does it still make that sound? It should not. There should not be a rough spot either. Keep me updated.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 04-10-2008, 05:49 AM   #1705
rankev11's Avatar
Sorry again, I forgot to include this engine is about a season old with good pinch. I bought it off a fellow racer who just stopped running it because it started making the noise. I was just wondering how to figure out if it is a rear or front bearing that has gone bad. Yes it stills makes the noise at temp. Is there any signs to see by looking at a ceramic to show it has gone bad??
Old 04-10-2008, 08:14 AM   #1706
ctsieber's Avatar
I wouldn't just replace the front bearing. Everytime I've had one that needed replaced the other wasn't far behind. Save yourself a headache, and do both.
Here's what I will use when my +12's are ready
http://www.murnanmodified.com/produc...roducts_id=229
ctsieber is offline   Reply With Quote
Old 04-12-2008, 05:46 PM   #1707
Gringer; What would be the performance advantages/disavantages of the Reddot Evo3 with the Skyline VR12+ and the Picco 2607 pipes?
NinjaRacer is offline   Reply With Quote
Old 04-14-2008, 03:11 AM   #1708
1fastdude's Avatar
Trader Rating: 15 (100%+)
Great job for the Murnan team and the racers that use Murnan products.
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 04-14-2008, 05:06 AM   #1709
advfuel's Avatar
Trader Rating: 29 (100%+)
Grinder, why is the sky blue
advfuel is offline   Reply With Quote
Old 04-14-2008, 05:58 AM   #1710
Ryan_Rhodes's Avatar
Thanks Uriah for the great horsepower this weekend at the U.S. Open in Kissimmee! I had one of the fastest cars down the back straight with great bottom end as well. The MM 12+ is a great motor! I can't wait to run it again at the Nationals in Ft. Myers!
~ Mugen Seiki USA | IDM Engines | Maxy's Fuel | Twister Tires USA | Ryan Harris Paintjobs ~
Ryan_Rhodes is offline   Reply With Quote
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
