Old 02-21-2008, 05:13 AM   #1621
Grinder's Avatar
Originally Posted by iiistyler View Post
Anyone heard from Uriah
his website says he is back on the 17th its now the 21st here in Australia
and I havent heard from him
We are back. What can I do for you?
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 02-21-2008, 05:23 AM   #1622
Grinder's Avatar
Originally Posted by grub View Post
gidday i have a nova 12-3 plus sct
im getting air in my fuel line and when its warm there a air bubble near my high speed needle and it wont move wont let fuel through either .
my engine wont start when warm as the air bubble moves up and down my fuel line even when the throttle in open it still wont let fuel into the carby.
it changes tune as it get warm,allso it will run great for about 4 laps then it sounds like it starving/flooding and no power a stalls .
allso idles erractic when warm...i blamed the fuel tank but the tank holds pressure,any help much appreciated
is a new engine
The engine is probably too hot. The metal carb is most likely vaporizing the fuel before it can get to the engine. The engine may also be getting too hot, and losing the compression needed to pump the fuel into the carby. How hot are you running the engine? You say the engine is new? If you still can't get the engine to run properly please send it to me, and I will test it. I have also seen dried up oil from the fuel, or after run oil clog up a carby. You may want to take the carb apart to check that. Have you had this problem with the other engines?
Old 02-21-2008, 05:35 AM   #1623
grub's Avatar
most of the time 115 deg c -125 deg c running #6 tf plug byrons fuel
no i didnt have the problem with the other engine ,i checked the engine temp yesturday it was 95 deg c and i put fuel in carby and it vapourized and bubbled so i rechecked the temp on the carby it was 90 deg c....
i tighting up my high speed needle body tonight to see if it was leaking through there ,so far it seams to be have fixed it on da bench
ill see on the track tomorrow. thanks grinder
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 02-21-2008, 06:26 PM   #1624
iiistyler's Avatar
Send a message via MSN to iiistyler
Uriah
I just sent you a PM and also an email through your web shop as Rctech is painfully slow
Cheers
Tony
V-ONE-RRR EVO 2
MURNAN MODIFIED 353 09 TUNED FULL CERAMIC STOCK 353 09 TUNED
FUTABA BRUSHLESS BLS551 3PKS + FASST
PROUD MEMBER OF THE MOOREBANK REBEL ALLIANCE
YOU ARE NOW ENTERING KYOSHO COUNTRY BEWARE
iiistyler is offline   Reply With Quote
Old 02-26-2008, 09:53 AM   #1625
ctsieber's Avatar
these are great motors for dirt oval racing as well. I've been running a +12 3sct all winter long, with great results.
ctsieber is offline   Reply With Quote
Old 02-26-2008, 10:05 AM   #1626
bugnet's Avatar
I canīt find in this thread, tips from Uriah to break-in an Novarossi modified .12 engine, anyone says any best way to do it ?
tkx
Kyosho V1RRR WCTEvo - Sirio Evo4 - East Civic - 3PM FASST - BLS451 - O'donnel 20% - GRP
TM E4 - MambaMax7700kv - Mazda6 - S9551 - VESC4300/IB4200 - Alpha R/C
bugnet is offline   Reply With Quote
Old 02-26-2008, 10:07 AM   #1627
ctsieber's Avatar
he has his break in methods right on the webpage.
http://murnanmodified.com/breakin.php
tkx
Old 02-26-2008, 11:28 AM   #1628
ma racer's Avatar
Default rb .21 schtuff
Uriah-
I am considering an RB motor from your stable. Any considerations for the new Alpha in the future? I run 1/8th onroad only. Or, would it just as well be better to get the C6.
Thanks in advance, Matthew
P.S. it was great to meet you at the Sedan Nats in Texas.
ma racer is offline   Reply With Quote
Old 02-26-2008, 11:33 AM   #1629
bugnet's Avatar
right,
I read that article, but who know, any time anyone could give a great tip or a pearl,
thanks
Old 02-26-2008, 06:10 PM   #1630
ctsieber's Avatar
Bugnet,
I will say this, the +12 took alot more break in then any other motor I've owned. So expect afew more tanks for break in.
right,
thanks
Old 02-27-2008, 12:55 PM   #1631
Hi, Murnan modified the engine Orion CRF????
cmpx is offline   Reply With Quote
Old 02-27-2008, 01:00 PM   #1632
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
I think I remember seeing it on his website on the modified version and the stock version. But since the engine has given so much trouble to setup, and so many recalls and updates, I think he stop modifying them. There is going to be a 2008 version coming out soon. IMO its an engine that needs to be tested and tested then retested again to get all the bugs out. If you need a proven fast engine get a Novarossi. The best who can answer the question is Murnan himself, but Im just giving you a small heads up.
eBay user id: riketsukirai
Selling all my MTX4 parts, bodies, radio and everything!
Riketsu is offline   Reply With Quote
Old 03-03-2008, 07:56 AM   #1633
Hi Murnan
What differences did you find between the Max Power 2602 pipe and novarossi 2630 medium header on the Nova Plus 12-3t? Thanks!
air jordan is offline   Reply With Quote
Old 03-07-2008, 03:35 PM   #1634
MTX4JR's Avatar
Grinder if your not to busy what modified parts do you have for the Novorossi NS12TS1 and also the N12LL3.
Either go Fast or go Home.
Car: Mtx4
Radio Futaba 3pk
Engine: Novarossi / Os Speed Tunned.
Fuel: Maxy / O' Donnell
MTX4JR is offline   Reply With Quote
Old 03-09-2008, 07:53 AM   #1635
Grinder's Avatar
Hi. I have the modified PS set, and modified crankshaft for the TS1. I have nothing for the LL3.
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 01:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 03:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 09:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 09:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-20-2004 12:01 AM
SEO by vBSEO 3.5.0
