PICCO P9 EVO 2
#76
#80
You turn the needles until it is tuned correctly! There is no such thing as optimal settings, if you are referring to counting turns. If you even know how many turns out your needles are, you don't know anything about engine tuning. Differences in fuel, plugs, atmospheric density, temperature, humidity, etc. will require far different needle positions to arrive at the same state of tune.
#86
hi anyone can help me with my question?
i'm running this engine, is the low end needle suppose to be very far out?? i had mine tuned to the screw out from card about 1.5mm, but engine is running ok.. am i running too rich ???
