Carburetor sealant
What are you using as carburetor sealant?
I need to seal my carb. regards |
Permatex , red rtv silicone sealer.
I use Air Seal too.
Much better and easier to work with than silicone sealer. its available from Racers Choice RC Products not sure if they have a website but they are is Austin, Texas Pm me for a phone number. |
you want Permatex "Ultra Copper"- http://www.permatex.com/products/aut...sket_Maker.htm
It is in a squeeze type tube and is copper/orange in color. It is a high temp, non-corrosive, fuel resistant gasket maker- ie.- you can use it on a real engine in place of a gasket. Clean your engine well so it adheres good. Use liberally around the carb to ensure you do not block any passages. |
Carb sealant
Thanks you
rccobra705 |
The main thing is not to put any sealant in the case opening, only put the sealant on the top of the carb shaft to keep any of the sealant from entering the case.
