Old 02-21-2007, 05:49 AM   #1
Default Please help me with me engine
I'm new to all this nitro lark and have a Hyper 7 with the standard engine.
Now, when I start the car it just revs like mad and I just cannot seem to be able to set the idle correctly - so I have to turn the engine off and turn something else and hope for the best.
What do I do because its driving me mad - I bought the car 2nd hand by the way.
Please help me with some base settings just to get the thing started.
evilevo514 is offline   Reply With Quote
Old 02-22-2007, 05:11 AM   #2
vti-chris's Avatar
Unscrew the idle screw to turn the idle down and also screw out the low speed needle to richen it some.
Take off the air filter and see the gap that remains open when the throttle is fully closed from the servo-arm.
You should see about 1mm opening.
vti-chris is offline   Reply With Quote
Old 02-22-2007, 01:37 PM   #3
MassiveMods's Avatar
If you find its not a tuning issue then check the following
Back plate is sealed and tight
Carb may be faulty .. put long piece of fuel tube on carb
place carb into water bowl with fingers over inlet and outlet
blow into carb..
You should not see any bubbles , if you do then you may have a problem
You can have some dirt in the carb, possibly in the HSN
Your Radio Throttle adjustment is out
Engine development manager Rifling Pty Ltd. Nitro fuel designer : Neo + World record title holder 2012 Austalian Nationals 147.6 KPH , 1 st 2 nd and TQ Australian National Buggy titles 2012. Victorian State title 2012 Neo + , South Australian state title ON and Off Road 1/8 2012 Neo + :-) QLD State Titles 2012 1st buggy & trruggy + TQ Neo + MG66 RX7 1st Sportsman Class Truggy QLD State Titles 2012 !! Nitro Addicts Australia . com
MassiveMods is offline   Reply With Quote
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 02:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 07:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 04:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 03:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
SEO by vBSEO 3.5.0
