Old 02-18-2007, 12:35 PM   #1
32819toon's Avatar
Default engine not starting
I'm hoping that someone can tell me what I'm doing wrong. I decided to go with a new pullstarter after mine popped out when I dismantled my new engine. The engine had gone into lock, probably flooded. Now, I'm having the same trouble. With the glow plug in the pullstart is very tight but OK when I take out the glowplug. The engine may have been flooded, but can't be now. Could the engine have damage ? As it still pulls without the glowplug is that an indication that the engine is still OK ?
Please help.
32819toon is offline   Reply With Quote
Old 03-01-2007, 12:45 AM   #2
gashuffer's Avatar
Trader Rating: 48 (100%+)
Remove the glow plug and give a couple pulls on starter to release excess fuel from the engine. Tilt you car so any fuel in your pipe will come out of the stinger.With that being done you should no longer be flodded"Hydro-Lock". By removing your glow plug, there is no longer any compression in your engine. This is normal. You might have a bad plug or dead ignighter.
gashuffer is offline   Reply With Quote
engine not starting? whitrzac Nitro Off-Road 5 06-27-2008 03:52 PM
Starting Up engine shaun_dini Onroad Nitro Engine Zone 1 02-17-2007 06:45 PM
ENGINE STARTING 32819toon Nitro On-Road 6 02-17-2007 12:56 PM
Need Help with starting up my engine! kmaheartless Rookie Zone 3 01-12-2007 10:41 PM
hpi rs4 3 engine starting srowell3 Nitro On-Road 9 01-09-2007 09:32 AM
SEO by vBSEO 3.5.0
