STS 30 modded crank pics
WHAT DO YOU POLISH YOUR CRANKS WITH IT HAS A NICE FINISH AND WHAT POLISH DO YOU USE, CRANKK LOOKS GREAT LOOKS LIKE YOU PUT A FLOW RAMP ALSO...
I'm sorry but I find it hard to believe you are rookie. That is too good a job for a rookie. Maybe your definition is a little skewed.
Otherwise, great job! It looks beautiful. What crank is the bottom one? Did you polish the crankpin if they are the same crank?
thank you for the compliments...
the crank on the bottom is a stock version of the crank I modded, except the crank I did was not black coated from factory...But other then the coating they are identical
Hey Maximo thats impressive ! Really good flow work there bud !
hey if you open a shop you could call it MaximoMods lol ... sorry it was funny at the time
What epoxy was used for the flow ramp inside the crank?
looks good
what type of tools did you use?
looks bad a_ _ and you have plenty of smoke comming out..
what engine is that ..
Oh I also had the opportunity to run the STS 30 in the pictures... I bought a new MBX5T and slapped the modded 30 in it... It was pretty wild to say the least, it ran like a champ and seemed to really over power the Mugens Chassis......... For the dollar I am really liking these STS mills, this new STS 30 is insanely powerful with very good RPM..
