Old 12-26-2006, 03:48 AM   #1
alexisonfire's Avatar
Trader Rating: 23 (100%+)
Default rb speedline
hi everyone bit of a new comer to nitro but still know enough to get me outof trouble i bought a rb speedline off e bay a mistake already some might say anyway thought i got a good deal two pipes and manifolds as well $399 took it apart and found a fracture starting at the gudueon pin going down to the bottom of the piston can also see from the inside of the piston the seller says it will be fine he is a mechanic and it should not affect it i believe otherwise then begun to accuse me that i had done it with a tool i was shitted off is it stuffed or not some advise would be great
alexisonfire is offline   Reply With Quote
Old 12-27-2006, 09:46 PM   #2
bsmooth's Avatar
Trader Rating: 17 (100%+)
I would go to rbproducts.com and post this in the forum section. You will probably get a reply from Rody, and go with what he says. I don't know as much as some of the guys here, but any fracture inside a micromotor (if seen with the naked eye) should be cause for alarm.
I hope you have good luck.
bsmooth is offline   Reply With Quote
SpeedLine Designs yfzrider Wisconsin & Illinois Racing 189 04-08-2010 06:15 PM
Speedline Sat may13th Speedlinehobbie Florida Racing 40 06-08-2006 08:42 AM
Speedline on the 30th ? The Hawaiian Florida Racing 15 04-30-2006 04:40 PM
SpeedLine Designs prodirt19 Painting, Designs, Graphics and Photography 2 01-17-2006 02:33 PM
anyone know where speedline is now? overtki11 Singapore R/C Racers 2 12-08-2002 04:06 PM
SEO by vBSEO 3.5.0
