Like Tree1Likes
JL Racing .12
Old 02-14-2008, 12:12 AM
  #1201
jscamry's Avatar
Originally Posted by tl2111
Jason, use the silicone tube without lip, it fits very well with nova type header. and is much stronger compare to NOVA original seal
Thanks for the tip, I put the silicone tube without the lip and it does seem to fit better, I will run the engine and see how it runs. I was having issues with the original seal with lip that came with the engine.
Thanks again, Jason.
jscamry is offline
Old 02-14-2008, 12:44 AM
  #1202
tl2111's Avatar
Trader Rating: 21 (100%+)
no problem, hope the tip help! btw the other seal is for picco pipe only
tl2111 is offline
Old 02-14-2008, 04:53 PM
  #1203
Trader Rating: 15 (94%+)
what is the stock setting on the bottom end for the evo 3?
mrgsr is online now
Old 02-16-2008, 07:57 PM
  #1204
jscamry's Avatar
Smile
I am not sure of the stock setting but I am still breaking in my engine and I have HSN set to 6 and LSN 4.
I hope that helps!!
~Jason
jscamry is offline
Old 02-16-2008, 08:08 PM
  #1205
jscamry's Avatar
Smile
I am not sure of the stock setting but I am still in the breaking-in stage, my engine and I have HSN set to 6 and LSN 4.
I hope that helps!!
~Jason
jscamry is offline
Old 02-16-2008, 08:35 PM
  #1206
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
ATleast you get to break in yours....mine is still sitting in the car awaiting its break in. Also, need new bearings for the clutch bell as well (not the thrust bearings).
HarKonnenD is offline
Old 02-16-2008, 10:35 PM
  #1207
jscamry's Avatar
What happened with your bearings? are they going bad?
Thanks Jason.
jscamry is offline
Old 02-19-2008, 03:16 PM
  #1208
Team Kamikaze's Avatar
Hello all, I was wonder if anyone knows the size of the exaust of the JL engine? I have a rdlogics pipe and header and it seems as though my header does not fit snug. I had an old nova mt12 that this combo fit well, but this is not the case with my JL.
Thanks Jason.
Use OFNA 51997 exhaust gasket for nova based header.
Team Kamikaze is offline
Old 02-19-2008, 04:30 PM
  #1209
aussies1129's Avatar
Trader Rating: 74 (100%+)
hey Sam,
is there anything special that I should know about changing the crankcase on an evo 3?I had a small crack in the tip/clutch end and it needed replacing, also i have noticed a small metal shaving on one of the ports on the piston is this ok as its just on the inner edge of the port?
thanks for your help
aussies1129 is offline
Old 02-19-2008, 08:39 PM
  #1210
Quietroit's Avatar
Can anybody help me with the part number of the crankcase for the JL EVO2. And where can i buy the crankcase from. And what is the factory setting for the carb. Thank you
Quietroit is offline
Old 02-19-2008, 08:49 PM
  #1211
Quietroit's Avatar
  #1212
Quietroit's Avatar
Old 02-20-2008, 04:41 PM
  #1213
Originally Posted by aussies1129
hey Sam,
Michael,
There is nothing special when changing crankcases, the JL2 and the JL EVO 3 had the same crankcase, I did not understand regarding your question about the metal shaving, on the piston ?
Old 02-20-2008, 09:43 PM
  #1214
jscamry's Avatar
Team Kamikaze-sam
How was the Nats? I called your shop, but you and your team was at the race. How did your drivers end up?
Thanks Jason.
jscamry is offline
Old 02-21-2008, 04:45 AM
  #1215
Michael,
HI Sam just read your post about the tuned evo3 can you pm me cost?
also regarding the metal shaving I will send you a photo.
thanks for your help!!
