JL Racing .12
#377
Well I finally got to run my car today and put it to the test. I must say that it is very impressive for only $180. This motor is a screamer and galloped down the backstretch when it hit second and start to climb in rpm's. Glad I bought an extra piston, sleeve and rod for it.
I see where some of u guys are having problems with fuel leakage, but haven't seen any sign of fuel anywhere on the motor during break-in or while running. Maybe u need to push down more on the carb b4 tightening or maybe not tighten too much to distort it.
#379
Hey Kurt, glad to see your having success with the motor. I started to break mine in last week. Seems to have some real kick to it. I can't wait to start trading paint with you on the back straight.
#381
Originally Posted by Team Kamikaze
Are you not running it way too Rich causing it to spit oil thru the front bearing.
Then when trying to get the low-end nice and crisp this would usually make the motor have no smoke at all. Then when trying to adjust the hsn richer to get some smoke , the motor would be significantly slower on the straight. Basically acting loaded up.
Im going to give a call to ofna soon on this one if I cant resolve it.
#382
Also what are your guys thoughts on the Skyline VR12 Plus pipe with this motor. From what I saw and was hearing its actually not such a good combo.
Has anyone had good success with the vr12 and this motor? What pipes are you having success with beyond the mega/idm pipe. Im also wondering if the ofna/picco pipe would work with this motor like a mega pipe would? They look similiar and it has the longer type header.
#383
when you measure the pipe and header it is not only the header that is longer. If you measure the pipe from the molding section to the end with the header conected it is about 6 to 7mm longer and that make a big difference. If you were to run the v12 plus, your best bet would be to use the nova long header 7 fin (i think). That will get the closest to the mega/picco pipe #2607. The 2607 with conical from mega is the best pipe for that motor. They is probably the same combo from idm, picco, offna, but I do not know the numbers on them.
#384
Who carries the #2607 pipe?
#385
#386
I had a similiar experience to yours with the engine not being able to tune properly and it turned out to be a piece of the exhaust gasket broke and blocked the pipe.
When tuning this engine, the bottom likes to be rich with lots of smoke. Just go slow with it and start off with a rich tune.
#387
leaking
Hi Guys,
Ive the same engine and I am very happy with the power. But I agree the other guys because the leaking problem is a bug. you can see some pictures. this was my first run with JL . You can see that the leaking is around the Ls needle.
#388
Read post #200 by roadrage.
#389
Yah I wasnt sure what pipe he was running , but sure enough here is what he said.
"I use mega 7 cold plug and mega 2607 pipe. i think im the only one using this combo and its off the chain as you can see."
Sounds like the mega pipes are the way to go. But im wondering if the VR12 is doable with it. I hope so , but what I saw at the track was pretty dissapointing. I thought the vr12 was a good combo with it.
#390
