Old 10-16-2006, 11:12 AM   #1
Default Weird engine sounds
I ran my car just now for about a minute or so... I have a LST2
it ran great... what I noticed, however, was a weird sound (i.e. I've never heard it before, this is my first nitro car)
When I got the car up to speed (lets say 1/4 of the throttle) and then got off the throttle, I would hear a weird noise - it was like the engine revving up... or maybe it was something in the tranny? Like one of those big discs?
Could it be that the LSN is too lean, and so it was revving up?
Can anyone help me?
D_o_S is offline   Reply With Quote
Old 10-16-2006, 01:36 PM   #2
RCRjuanabbe's Avatar
Is it a grinding noise? i.e. bearing going bad? or is it just revving up after the throttle? if so it is just LSN too lean.
RCRjuanabbe is offline   Reply With Quote
Old 10-16-2006, 04:57 PM   #3
mugenb46's Avatar
also check that your radio is set to close the carb properley, when you let of it may slow down but not close the carb to where it would idle normal. if it's ring tinging of throttle idle needle may be set to high as well or be leen on the bottom. hope that helps.
mugenb46 is offline   Reply With Quote
Old 10-17-2006, 04:04 AM   #4
hav_lova's Avatar
Lift it off the ground and give it a revv then full brakes and see what happens, if it seems to linger at high throttle it could be overly lean or an air leak.
Try tuning it again from the base settings for that engine and check your linkages and let us know what happens
Just playing with bigger toys now...
hav_lova is offline   Reply With Quote
7 engine rc truck that sounds impossible..??????? zack54321 Onroad Nitro Engine Zone 4 06-23-2008 02:06 AM
Something weird about starting my engine I noticed over the weekend.. Furadi Nitro Off-Road 3 04-07-2008 04:54 PM
Sounds like a new buggy in the works Briguy Nitro Off-Road 6 10-06-2007 11:50 AM
sounds comming from my rear end kh15 Electric On-Road 9 08-16-2004 11:59 PM
Ps2 & Surround Sounds Systems!!!! jmalt Other Items: For Sale/Trade or Wanted to Buy 2 09-25-2003 09:58 PM
SEO by vBSEO 3.5.0
