Old 10-13-2006, 04:33 PM   #1
maresma's Avatar
Default OPS engine break-in
I bought a brand new OPS 3.5 Buggy engine (.21 size) which won't crank.
I measured the sleeve, it has 16.5mm at bottom and tapered to 16.0mm at top (approx 3mm from top of sleeve). The piston diameter is 16.2mm
My question: is it normal to have 20micron interference of piston and the top portion of the sleeve? I couldn't turn the flywheel, and my starter box couldn't crank it even when i tried heating up the top of the engine.
On the other hand, my OS .21 VR can be turned using the same starter box even when it was new.
Any advice?
Thanks in advance
maresma is offline   Reply With Quote
Old 10-13-2006, 07:46 PM   #2
mugenb46's Avatar
ops may have a more tighter tolerance at top dead center when new as far as breake in go to the engine wont run thread on the second page of the nitro engine zone i posted my brak in methed their, it works grat and that motor will last. the motor may need to be heated up quite a bit, if 200 to 220 dont do it then apply a little more, but once you get it going you will have to keep heat on it or it will lock up from cooling down. good luck
mugenb46 is offline   Reply With Quote
Old 10-14-2006, 12:43 AM   #3
maresma's Avatar
Thanks mugenb46 for the input.
How not to break in an engine ! Maximo Nitro Off-Road 4 08-05-2008 09:34 PM
engine break in 37 RACING Nitro Off-Road 10 03-15-2008 02:25 PM
Engine break-in ? acsubie Electric Off-Road 3 05-11-2007 07:42 PM
How do you break in an engine? joe of loath Rookie Zone 12 03-26-2007 03:08 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
SEO by vBSEO 3.5.0
