Old 09-28-2006, 08:27 AM   #1
Default Which fuel (for Mach 427)
I have a Mach 427 in my LST2. I have just completed running 2.5L of 16% nitro for break in purposes. I have to purchase new fuel... should I stick with 16% or go to 25% Nitro? When switching to 25%, I guess I should re-break-in the engine (take it easy for the first few runs)?
Which of these is the best fuel:
1)Graupner 25%
2)Orion Black Demon 25%
3)RB Concept fuel
4)RB Monster fuel 25%
5)Power save racing fuel.
Thanks in advance
D_o_S is offline   Reply With Quote
Old 09-28-2006, 08:42 PM   #2
wallyedmonds's Avatar
tornado and you should break in with the fuel you are going to run,and if you like 16 stay with it its easier to tune and its harder to over heat i mostly run 25
wallyedmonds is offline   Reply With Quote
Old 09-29-2006, 08:38 AM   #3
So I ended up buying the Orion Black demon 16% (they didn't have 25%).
Well, the engine runs completely different compared to the Graupner fuel that I was using. I started off with the same settings that I used for the Graupner fuel, and here is what I noticed:
1)The engine runs much, MUCH cooler (with the stock needle settings, it would only get to 50 C!!!) (I think that with the Graupner, because it prolly has less oil (it only has synthetic) and the Orion has both castor and synthetic, the orion runs cooler at the same settings, but with much less performance)
2)After leaning out the HSN and LSN a bit, I managed to get the temperatures up to 70 - 80 C, with performance near to the Graupner fuel.
I must say that I am surprised (so far) how good this fuel is! I didn't have any more fuel with me, so I didn't continue leaning it, but I will do tomorrow. I think that if I lean it out another 3 to 4 hours, I should have great performance, with temperatures in the 100C range.
Is it important to watch for the smoke? Or should I only watch temps? The smoke coming from this fuel seems much lighter than that when I used my Graupner.
Old 09-29-2006, 09:21 AM   #4
razzor's Avatar
I would say keep at the 110/120 mark and it should have puff of smoke as it accellerates ,not thick smoke but smoke.also when engine idles it should build up or idle should drop ofter 8-10 seconds ,my truck and buggies run on 25% nitro,9% oil and with this fuel after it builds up for 10 seconds and i throttle it it is usually a bit flat and on second throttle it is a clean rev.
Also almost forgot ,always set hsn for a decent speed and then the lsn.
my 2cents, hope it makes sense and helps.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
O'Donnell Racing Fuel vs. R2R Fuel SKOT Nitro Off-Road 4 12-28-2007 06:34 PM
Tower Hobbies Power 20% nitro fuel VS Trinity Monster Brew 20% nitro fuel? needhelpPLZ? Nitro Off-Road 1 07-23-2007 05:01 AM
WTT: Used DYN Mach .26 with Cooling Head for Mach .21 absolut_racer R/C Items: For Sale/Trade 0 02-28-2006 07:45 AM
<NEW> MONSTER TRUCK FUEL FROM MAXY'S PRO RACING FUEL !!!! <Maxy's> Nelson Racing Forum 0 11-08-2005 09:13 AM
Does O'Donnell fuel make a huge accel. gain on HPI fuel Smoke21 Nitro On-Road 3 05-03-2004 04:44 PM
SEO by vBSEO 3.5.0
