Bore vs Stroke vs Displacement
#16
Originally Posted by rmdhawaii
Hmmmm... More interesting info...
Check out the graph guys....
http://www.axialracing.com/details.p...imgID=1&type=2
mxwrench!
Code:
Engine Bore Stoke Disp. ------ ----- ------ ----- Axial.12RR Spec 1 13.76 14.00 2.082
mxwrench!
Dave
#17
Originally Posted by DaRollaRacer
If you look at mxwrench's comparisons of the JP and the TOP, they're similar to what Axial's results were for the respective engines. Assuming both Axial and mxwrench's dynoing methods are similar because of these results, we see that the Novarossi LS3, Sirio Evo 3 and the Orion Wasp are more powerful.
Dave
Dave
#18
im gona stay with jp and novarossi from now on WHY DAVE you know why i cant run the damm sirios there not for me cuz i break them all the time. and now the LL3 has more torque whether you feel it or not the LS3 has less. the sti has more power i dont know how to explain better but the ninja should have more power.
#19
Ahh, that's too bad Wally. I liked the fact that we were the only two to venture beyond the mainstream Novarossi engine.
Dave
Dave
#20
ok ok ill get a crank for it but i still have my evo2 i just need a button and a con rod oh lol a carb.
#21
Dave
Dave
So if you want to make your decision-chose for your self-is this modded or stock then you have choice in modded and stock engines.
BTW, Axial motors 2 nd place on winternats and it was running against one of moddifyed engines from your list (literaly) and won it, PreNats 1 st place, Texas Biggie TQ and won etc-I don't have time to list everything. If engine is not powerfull how is that happened?
#22
Registered User
#23
Originally Posted by COREX
All you need to list is the last biggest race The IFMAR SEDAN WORLDS in Australia What Happen to AXIAL I guess nobody wants to run it because they know the motor is not fast enough meaning Too SLOW, the only reason axial won the Texas biggie is that no body else was there to race, if Swauger or Cyrul is there axial would have not TQ or won at all, i guess you can't bragg about axial winning anymore because you run out of drivers that are willing to run axial
Edward
#24
Thanks Edward. I understand what you getting at.
#25
Osiris 75, Dave and Wally: Thanks guys! Really appreciate the continued feedback and support.
Kyosho should send you guys a free t-shirt or something.
#26
Registered User
On Winternats everybody (or almost everybody ) was there,On PreNats Swager was there, also Tosolini, On Nationals Ron Atomic went straight to the A-main and finish 7th. Worlds, why would we go to the worlds spend tons of money and don't have top level driver-all of the top level drivers unfortunately for us had contract with other companies-to get 27 th place?As far as nobody wants to run our motor-well I think it is your guess-so far it was represented well, got very good results (see above). I think it is pretty good for start. And belive me it will continue like that. Please remember and talk to people in RC community, if I sad belive me, then it means this will happened. So far for last 3 years nothing what I promised was faulty.
Edward
Edward
#27
Well, I believe the drivers made a good choice not running Axial, because they know it is not fast or reliable, well I saw some of your post saying it will never overheat, yes it may not overheat but when you run it and it temped in at 400 + degees the motor flames out anyways causing vapor lock (preventing fuel to reach the carburetor resulting in to hard to start or no start at all) so what good is the motor if you can't get it started, Axial will be a great motor............well maybe someday........ if you find the missing link. but for now please be humble, do not try to be too proud of it until it is proven consistent and tell Axial to lower it to about $150.00 then maybe it will be worth the money nor $300.00+ that's a joke
#28
Originally Posted by wallyedmonds
maybe ill try one of these axial motors and see and if it blows up like a os ill say here
Do you destroy engines on a regular basis or is this something new? By "os" do you mean an O.S. engine??
#29
Mate what engine/s do you run ,have you owned a Axial to justify you dissing it ???
#30
Wally! Is this why you've got problems with your STI cranks?
