Old 08-21-2006, 09:36 AM   #1
Default Novarossi .12 HELPP!!
hey guys, i fink my novarossi is a cx12 wit a pull start starter
wen i apply the throttle quickly to full, it starts to bogg and choke at the high end and stalls if i keep it at full thorttle
but wen i apply the thorttle gently to full thorttle it isnt too bad
what am i doin wrong???
and my bro has mess up all my needle settings including my mid range
so please can i have the standard needle settings for all needles please
thanks and please help
bigboss is offline   Reply With Quote
Old 08-22-2006, 01:59 AM   #2
just tried out engine agen, and been doin abit of research on needles.
i have set the mid range needle to flush, i hope thats the stock setting.
it can rev up to max witout choking, its working better now but still abit confused on my needles
can i ask wot everyons needle setting is
Old 09-11-2006, 05:43 PM   #3
mugenb46's Avatar
hey boss it is easier than you think. the mid should be flush, the needle at the top controls high speed, and more inportant tempeture.before when you just cranked on it you were probabley to fich on top if it didn't die. your temp should be the last thing to worry about, just tune to the feel of the motor. as long as you see blue smok from start to full revs your good. know whaen you start of if it studders and spits out fuel don't go crankin on the needles yet, let the motor build some heat, when you tune is wright it should do that. if you start the motor and it is at full tilt buggy as soon as you pull the gas your to lean then you will cook that sucker. you should run the car around to buid heat to race temp what ever that is, then come to a complete stop wait 10 seconds then pull it. when tuned right it will take off with good force and you can hear the revs clime. know if it dies when you pull it it can be to lean(not enough fuel) or if it feels slugish (to much fuel) you will adjust the bottom end needle.1/8 of a turn on the needles always. nova carbs are very sensative to tune or when you turn it you will notice it. so if it takes good then dies to rich or to lean again on top. if it takes off good then gets slugish it is to rich, or if it dies it is to lean, give back some fuel. always tune on the needles when the motor has heat in it uselly abouve 200to 210. then start adjusting. that motor should run great from 210 to 240. depending on what you are running it in. on road 240 off road 210 220.
hope that all helps
mugenb46 is offline   Reply With Quote
Old 09-14-2006, 09:39 AM   #4
aaalp's Avatar
Send a message via ICQ to aaalp Send a message via MSN to aaalp Send a message via Yahoo to aaalp
Thanks mugenb46. Pretty good explanation you got there.
aaalp is offline   Reply With Quote
Difference between Novarossi 51603 tuned pipe and Novarossi RB x12 tuned pipe? racer rich Nitro On-Road 8 11-06-2010 06:52 PM
FS: 1/8 Kyosho Evolva + .21 Novarossi 359 + Novarossi .21 pipe + Tons of spares WogBoy Australia For Sale/Trade 6 05-15-2008 05:32 PM
Novarossi Plus 21-5KT (Turbo Plug) New in Box, AND Novarossi 21P5XS less than 1/2 gal nobike R/C Items: For Sale/Trade 29 03-31-2008 11:00 PM
Novarossi N528XR and Novarossi EFRA-9853 For Sale BAMF90 R/C Items: For Sale/Trade 9 10-11-2007 08:29 PM
MOTOR HELPP!!!!!!!! TRINITY D6 10X2 FLAT WIRE Ae13291 Electric Off-Road 5 01-01-2007 03:22 PM
SEO by vBSEO 3.5.0
