Old 08-08-2006, 05:35 AM   #1
Trader Rating: 12 (93%+)
Default pros & cons of aluminium piston liners in engines
i just wanted to ask you guys what your thoughts were on aluminium piston sleeves in engines.
how do these compare to the typical brass sleeves ?
Serpent 748 TQ | Picco EMX
BlueRC | www.bluerc.net
VP Racing Fuels
mrgsr is offline   Reply With Quote
Old 08-08-2006, 06:11 AM   #2
Team Kamikaze's Avatar
The Aluminum sleeves wear out faster, but motors with Aluminum sleeves are usually insane fast.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-29-2006, 07:06 AM   #3
duneland's Avatar
I am told, that it is more difficult to get the chrome to adhere to the aluminum. So it is more likely that an aac sleave will start to flake the chrome off.
Theory is, that the alum liner will expand and contract at same rate as piston & crankcase. Making it hold a tune better throughout the operating temp range. Weight is down too.
duneland is offline   Reply With Quote
Old 08-29-2006, 07:57 PM   #4
nitrodude's Avatar
When Sirio came out with their Al. sleeve engines, a lot of people had problems with the sleeves breacking prematurely, the same thing happend when Novarossi came out with their 421p Al sleeve engines. Someone on the forum mentioned that the problem was that the sleeve would get loose on the case and vibrate, causing it to break.
Steven Muller
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-29-2006, 08:46 PM   #5
wallyedmonds's Avatar
the alm sleeve is so much faster with less bottom,will crack in time instead of wearing out.
wallyedmonds is offline   Reply With Quote
Pros/Cons on AE 18R Huffpie Micro and Mini Scales 5 12-07-2008 06:11 PM
pros and cons MMS2 Rookie Zone 13 11-11-2007 03:30 AM
Pros and Cons! Bobby J Electric On-Road 6 01-06-2005 06:15 AM
pros and cons of XXX-S & TC3 jiggamacdaddy Electric On-Road 15 04-30-2003 09:09 AM
pros and cons on the v-one rr fuse01 Singapore R/C Racers 16 04-05-2002 12:39 AM
SEO by vBSEO 3.5.0
