Nitro injection system
Originally Posted by Orfeous
That has to be the craziest performance upgrade I have seen for a 2 stroke nitro engine.. They even have small little Super Chargers...hehehhe
only a 30% increase in performance with the hpi k4.6 engine........not realy a big increase.....with the extra 200 bucks u gotta fork out for that system you can buy an even better engine and a nice pipe and get better performance.....
and these things make the engine runs outragiously LEAN....wich aint good
A supercharger on a glow engine will not work all that well due to the fact that the pressure in the cylinder determines when the mixture is detonated. If you increase the input pressure you advance the timing of the engine to the point of pre detonation. It will only benefit a poorly tuned engine
Cheers
Cheers
