O.S. .12 TZ(P)-T3 Speed Tuned
#91
Originally Posted by uniquexme
yesterday, i swapped my palmaris engine with OS Speed, and i changed a pipe, so i need to retune my engine. then until today, i found out that there is this weird problem with the LSN, if u lean it too much, the whole throttle linkage doesn't want to move, its just stuck there. so i opened up the carb, clean everything, reinstall back, and its the same. so i would like to know if its the case for OS speed engine? coz for my palmaris, my LSN, i set it to very lean, only about 1/2 turn out (u lean it until the screw ends, then turn out by about 1/2 turn), but for my OS Speed, its not the case. can anyone share this?
#95
Breaking in the Speed
Use heat gun to warm up the head to expand the p/s
1 tank idle, see to it that there is a lot of fuel/oil mixture spitting out
3-4 tank half throttle
then start giving it more throttle after the 5th tank
no need to adjust any settings till 12th tank then start to race tune it.
don't forget to change out your plug
good luck
ss
good luck
ss
#96
3-4 tank half trottle
then start giving it more trottle after the 5th tank
good luck
ss
good luck
ss
#97
Originally Posted by bvoltz
thanks for the info... but my question is if you idle one tank, are you concerned about getting the engine up to 200? Or not on this tank? On the rest of the tanks, is the goal to increase the engine temp to 200 and keep it in that range? I would assume more or less throttle is the tool to take the engine into the correct temp range, do I understand this correctly?
#100
Just don't expect it to ever show up!!
#101
#102
Its all good
I just had an EXTREAMLY bad experiance there...and so did alot of other people.
Its ashame the threads got deleated!
#104
os speed
Originally Posted by hyper7vspec
where is the best place to buy a speed tz?? wheres the cheapest shop that i can order online from??
thanks
thanks
www.kamikazercracing.com
