Old 06-26-2006, 06:43 PM   #1
Send a message via MSN to Adim_X
Default Collari XS 200 problems please help
Hello, I have a 3 port turbo collari xs200. Does anyone know what the stock base carb settings are. I am having a bear of time getting this to run properly, or even start. thanks
Adim_X is offline   Reply With Quote
Old 06-27-2006, 06:57 AM   #2
HSN 5 full turns from close
LSN 3.25 turns from close
the mid needle should be flush with the carb casing
take the carb off, put some sealant around the o rings and pinch bolt, refit the carb.
i did notice on my engine that the front bearing leaked around the shaft, to fix this i simply used some bearing fix liquid, high temp, medium strength.
MisterLister is offline   Reply With Quote
Old 06-27-2006, 02:39 PM   #3
Sp Racer's Avatar
Check that the low speed jet has been drilled , I had 2 that weren't.
PM me if you need explanation
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
EOI: G4 + Collari .12 LogiK Australia For Sale/Trade 2 06-16-2007 12:43 AM
Hyper Pro upgraded - Collari B3 Team Edition Collari Pipe axle182 R/C Items: For Sale/Trade 2 10-05-2006 11:25 AM
Collari b7 problems why and when Electric Off-Road 2 05-12-2005 05:27 AM
Collari XS .12 R3VoLuTiOn Onroad Nitro Engine Zone 7 07-16-2004 12:42 PM
m.collari-jp rex-tq mod Testaniracing Onroad Nitro Engine Zone 5 02-26-2004 09:06 AM
SEO by vBSEO 3.5.0
