Team Orion CRF Wasp Rev X-Dyno results
#766
Originally Posted by Kenneth Tan
Anyway, how are those rpms that were mentioned were measured? Tachometer?
#767
Originally Posted by Nano
Mxwrench has a system that precisely checks when the gears switch. He also built a dyno for nitro engines. So the figures he gives are accurate
I attached screen shot of that software. I am sorry for right side blank field-I have double wide screen monitor system and don't know how to get rid of second screen image in cases like this
#768
Somebody have experience with this engine in NTC3? What gearing you use and what clutch?
#769
Ran the wasp engine for the first time on track this weekend. Had great hp, but not much run time (4-5 min.). HS needle was 7.25 out, ls needle was 5.25 out. The engine just would not keep its tune. One time it would come in real rich the next it would come in screaming hot. When kept its tune it was a rocket. I thought that I read somewhere that was was an issue of the carb leaking air around the neck. If anyone has any suggestions please let me know.
#770
Make sure its not the exhaust gasket. Mine was broke and ended up blowing a hole in the bottom of the crank case as it was too hot.
I need to run the new one in now!!
#771
You might want to start out next time with your LSN at 4 and HSN at 6.5. Initially, you should be able to lean out your HSN without touching LSN. After, adjusting the HSN, depending on how it runs on the low end, you may or may not be able to lean out your LSN. Also remember to read this page at Team Orion:
http://www.teamorion.com/FAQ/Wasp+Rev+CRF+Tuning
Hope this helps.
#772
I broke the motor in per the instructions in the manual that came with the motor. I was using the RD Logics 62506 pipe and header. The temps would come in one time 305, richen it up a little then it would come back in at 165. They were just up and down. I took the motor out of the car in the last couple of days and the exhaust gasket was torn and the o-ring that seals at the base of the carb and the case was out of place.
Don't know if this could have been causing an air leak, but couldn't have been helping.
Thanks.
Thanks.
#774
New carb parts
Josh, what are the setings with the new carb updated parts ?
http://www.teamorion.com/news/ca40/newsid/141
CRF Wasp REV .12 updated
2006.10.27
Following Josh Cyrul's great performance at the 2006 World championships, Team Orion is releasing an updated version of the CRF Wasp Rev engine. The engine now features improvements developped by the CRF R&D department and Josh Cyrul himself. Modifications have been made to the main needle holder and the carburator body, also the carburator inlet now has a conical shape. The engine is now easier to setup and has more low end torque.
Team Orion will replace the main needle for free to all customers and the updated carburator body will be available for a nominal fee.
Customers that wish to get the updated main needle holder can contact their local Team Orion office.
2006.10.27
#775
Are the mods just to the carb? or are there other differences such as timing etc??
#776
Way to go Josh, looks like all that research work you were doing paid off!
This is good news! I am pleased that Team Orion is standing behind it's product and addressing some of the issues that we have been having. It would be great if we could get a detailed explanation of what each modification addresses and how the engine's tuning and performance characteristics change. A lot of us have gotten use to tuning the engine a certain way and it would be good to know if we need revise some of our thinking.
Some of the more specific questions I have are:
- Does this mean we no longer need the chassis specific CRF clutch parts?
- Do the carb changes alter the run time of the engine?
- Does the engine still start to bog when the humidity increases?
- Do these changes alter the initial HSN/LSN settings?
- Why is only the needle holder being changed and not the needle itself?
- Can we get a before and after dyno graph??!!
- What is the nominal fee for the updated carb body??
Inquiring minds want to know!!
Thanks!
Thanks!
#777
I'm gonna try to answer a few of the questions.
We still encourage users to buy one of our clutch sets as it will always perform better than the original stuff when using our engine.
No.
I am not aware of this problem, could you be more specific?
HSN setting is now 4 turns out from fully screwed in. The needle now rests deeper in the holder. LSN is the same.
There is nothing wrong with the needle. To allow easier setup, the holder hole is now slightly bigger, this way the needle has to be screwed or unscrewed further to change the setting. This helps a lot with the engine setup.
I will see about that.
I will get the info.
Another modification is to the carburator body itself, the bore is larger than before. This improves the low end response of the engine.
The conical inlet gives better throttle response troughout the rpm range.
No.
#778
#779
Thank you for taking the time to answer my questions Nano.
I am looking forward to getting the new parts and testing the engine.
#780
You're welcome RMD.
The updated parts are being shipped and will be available anytime.
As stated before the needle holder is free and the updated carburator body is offered with a 50% discount.
