Seeking carb O-ring for NovaMega KHM
Greetings, all
I am desparately seeking an O-ring for my NovaMega SX21KHM Evo6 engine.
I am not looking for the 2765 O-ring that fits over the end of the carb.
The O-ring I need is the one that goes inside the crankcase, deep within the case at the bottom of the cavity where the carb slides into. The stock O-ring is frayed and cut a bit. I took it out to examine it, and found that after I took it out it has also swelled up enormously so that I cannot put it back into its groove now.
The approximate dimensions are: 1.6mm thick, and slightly larger than 15mm outer diameter. I believe that the outer diameter may be slightly larger.
I cannot find a parts list that shows this O-ring.
(I have attached a picture.)
Can anyone help me out, please?
Novarossi part number 14002
