Old 03-06-2006, 01:41 AM   #1
PRospeked's Avatar
Default Are engine break in benches any good?
Was thinking of getting an engine break in becnh, are there any advantages and what the best one to get?
PRospeked is offline   Reply With Quote
Old 03-06-2006, 06:07 AM   #2
The advantage of using a breakin bench is that you can use near full throttle with a very very rich high speed needle. Also the prop will create a simulated load on the engine which you don't get by some of the "normal" breakin procedures that tells you to have the car off the ground.
Basically more fuel can go through the engine (also meaning more oil) and more heat can be used to "seat" the internals.
For my R1, we used 1 tank at idle (do this primarily for the rod, bushings/bearings, and other small parts), 1 tank at 180 degree F, 1 tank at 190 degree, and 2 tanks at 200 degrees, plus a couple of tanks of light in car running on the track.
Sorry I can't give you any recommendations for commercial breakin benches. I used a friends homemade bench.
darkangel is offline   Reply With Quote
breakin benches spudly12 Nitro Off-Road 11 01-24-2008 06:10 AM
How do you break in an engine? joe of loath Rookie Zone 12 03-26-2007 03:08 AM
Good break in temp? aus jd 2703 Onroad Nitro Engine Zone 2 11-26-2006 02:29 AM
having a break lots good deals FUK_WRX Australia For Sale/Trade 92 05-10-2006 01:31 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
SEO by vBSEO 3.5.0
