next truggy motor
#32
Forget making a 454 turbo (IMO).,
http://www.amainhobbies.com/product_...-Clutch-System
You could probably get a new 454 w/pipe*on ebay plus that clutch, a CB and a couple plugs for less than the price of the Picco.. Amain also has the OD plugs..
* The stock Losi RTR pipe is pretty good...
#33
I saw a video of the picco boost and that thing hauls a** I would get it for sure!
#34
Fastest
Higher CC generally means more torque, but for a truggy a .28 has more than enough. As you go up in CC, you lose revs generally. For most race truggies a good .21 is plenty.. IMO a truggy will be faster with an LRP Spec 3 .28 (or the Losi 454, which is identical), than with an LRP 30.
A lot of people like Picco, and I've liked the .21's I've had. I also like the LRP Spec 3/Losi 454 though, given they cost half as much... I know some people will say the Picco is faster and "better quality", and that may be true. It won't be twice as fast though..
I've had a bunch of LRP's though, so I'm keen to try a new Picco Boost. So that's why I said Picco.. For a basher truggy with a .28 I'd also get a Fioroni slider clutch..
For the money, Losi 454(closed backplate), JP-2 or JP-3(So far I REALLY like the 2047 too..) and the Fioroni clutch and you're sorted. Odonnell purple plugs..
#36
I have both too. And the 30 won't "stomp" the .28 in a single-speed truggy.. The .28 has more top end. Maybe up a hill with the extra torque... But a .28 is excessive for a truggy as is... The .30 is a good engine, but not for 200 bucks.. If you want to spend that get the Picco...
#37
how about a P5XLT?
#38
Wich motor would be better for truggy?
I have a Mito 4 and a bullitt b220 comparable to the os speed b2101. I had a legend .25 motor from the nitro shop in it but shit happens and I ended up breaking off part of the skirt on the piston so theses are the motors I have to work with for now. So which one would u run in buggy and wich would u run in truggy?
#39
I would say Mito 4 in buggy and the Bullitt in the truck.
#40
You could get a new stock Legend from novadirect for like a 150 bucks I think.. Just FYI..
#41
Yea u can I just allready have those motors. My wife is ready to kill me as it is so trying to keep from buying another motor.
#42
What size tracks? How's the grip level? For some tracks, a 4 port might be just fine in truck. But if it were me, I'd run the b2101 in truck with a 2050 pipe.
#43
Truggy: Mito 4 with a 9853 or 2058 pipe and a square header like the 41001, 41005, or 41032 conical. Bullitt B220 with a 2050, 2090 or the 9853 with a square 41001/41005/41032 conical header
Both engines will work in either applications. They will work a little better if you pair them with the best pipe/header combination for the vehicle so you might make you choice based on the pipes/headers you have or want to buy.
#44
You want to run the Bullitt engine in the truggy. 4-port for the buggy.
I'm sorry Sir, but recommending a Nova 4-port for use in a Truggy is just not on.
Typical nova 4-port characteristics is a weak delivery on the bottom end, which is great for buggy, but absolutely not what you want for a truggy.
#45
[/QUOTE]I'm sorry Sir, but recommending a Nova 4-port for use in a Truggy is just not on.
Typical nova 4-port characteristics is a weak delivery on the bottom end, which is great for buggy, but absolutely not what you want for a truggy.[/QUOTE]
I see your point and your right. The Bullitt would be the better choice for a truggy.
