Like Tree1Likes
Is this correct?
Old 08-19-2017, 01:08 PM
Default Is this correct?
is this the correct way for this flywheel not or does it need to be flipped?
https://www.youtube.com/watch?v=08ej...ature=youtu.be
Zep71 is offline
Old 08-19-2017, 01:18 PM
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Cant open it its password protected.
1/8 IC Fan is offline
Old 08-19-2017, 01:25 PM
ok no idea why let me check
Zep71 is offline
Old 08-19-2017, 01:28 PM
Zep71 is offline
Old 08-19-2017, 02:02 PM
1/8 IC Fan's Avatar
Check this drawing out from HPI. What clutch did you get the Kyosho one?
I added the one from Kyosho as well.
Attached Thumbnails Is this correct?-hpi-clutch.png   Is this correct?-kyosho-clutch.png
Old 08-19-2017, 02:57 PM
yes i got Kyosho
<a href="http://s660.photobucket.com/user/zep71/media/IMG_24991.jpg.html" target="_blank"><img src="http://i660.photobucket.com/albums/uu321/zep71/IMG_24991.jpg" border="0" alt=" photo IMG_24991.jpg"/></a>
Zep71 is offline
Old 08-19-2017, 02:59 PM
[IMG]<a href="http://s660.photobucket.com/user/zep71/media/IMG_24991.jpg.html" target="_blank"><img src="http://i660.photobucket.com/albums/uu321/zep71/IMG_24991.jpg" border="0" alt=" photo IMG_24991.jpg"/></a>[/IMG]
Zep71 is offline
Old 08-19-2017, 03:01 PM
sorry i can't seem to get any thing to work from drawings it seems like i have it together correctly
Zep71 is offline
Zep71 is offline
Old 08-19-2017, 03:07 PM
Zep71 is offline
Old 08-19-2017, 03:09 PM
OMG why did that post twice? anyway i think i have it together i will update after i get it in the truck.
Zep71 is offline
Old 08-19-2017, 06:00 PM
1/8 IC Fan's Avatar
Dont forget to set your gearmesh, there are four screws that hold your motor mount in place, you just have to loosen these and adjust so that your mesh is not too tight or loose.
Also check out: https://www.youtube.com/watch?v=tLzuSgCbpyg for setting your clutch bell endplay.
Old 08-19-2017, 08:11 PM
Zep71 is offline
Old 08-19-2017, 08:12 PM
Zep71 is offline
1/8 IC Fan's Avatar
The bell should not touch your flywheel. How far is the flywheel from the crank case.
You should have the locking cone on the crank, then the flywheel.
