Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Like Tree2Likes
Old 03-16-2017, 07:40 PM   #16
Lol my r7 I turned once and never had to mess with it again. They just have some a.c. issues it seems. Switched to the werks b7 ports and b5 pro and haven't looked back since!
rotor head33 is offline   Reply With Quote
Old 03-19-2017, 07:08 PM   #17
vandalzzz's Avatar
If you already have 2090 pipe, it would be much easier for wallet to hit the 2102.
TKI4 / OS B2101 + 2090 / Savox / Sanwa
Exclusive sponsor: my wife's patience
vandalzzz is offline   Reply With Quote
Old 03-19-2017, 07:44 PM   #18
well between os and reds i can get the os for about 100 or so cheaper and is probably better engine.
Rafa_kyosho is offline   Reply With Quote
Old 03-19-2017, 07:47 PM   #19
Frank L's Avatar
Trader Rating: 148 (100%+)
OS 2102 or Spec III
Motorman007 likes this.
Old 03-20-2017, 10:16 AM   #20
Originally Posted by Frank L View Post
OS 2102 or Spec III
2102 already have a spec 3
Old 03-20-2017, 11:58 AM   #21
maddog9's Avatar
Trader Rating: 29 (100%+)
I would definitely take a look at the Mitro 4. Another guy and myself were able to make 10 minutes on a tank of gas in nitro buggy A-Main both running the Mito 4. I was running a 6.5 venturi and still had what I feel was too much bottom end. My dad who has been a hardcore OS guy has starting running a bonito 21-7xlb and now is considering selling his OS 2101's and OS V-Specs.
dan_vector likes this.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 03-20-2017, 12:56 PM   #22
dan_vector's Avatar
Trader Rating: 27 (100%+)
Absolutely. Novarossi went through a bit of a rough patch with the keep off and the virtus engines but they've really sorted it out with the Mito. Fantastic engines in both the 4 and 7 Port configurations. Incredible runtime and super stable tune. You can also look at the Ielasi Tuned engines which are novarossi based and hand Tuned also extremely good. I would choose one over the OS or Reds any day of the week.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 03-20-2017, 04:32 PM   #23
Thanks guys really appreciate the feedback for mito line??
Old 03-20-2017, 04:33 PM   #24
do you know anything about the novarossi pre running? Is it break in just for them to make sure everything fine?
Old 03-20-2017, 06:32 PM   #25
dan_vector's Avatar
The pre-run engines have been bench ran and so partially broken in. You need to finish the break in process in your car.
Old 03-20-2017, 08:12 PM   #26
Real question is it worth the extra 30-40 or is pointless
Old 03-21-2017, 03:49 AM   #27
maddog9's Avatar
I probably would get a pre-run one. The novarossi's are super tight when they are brand new with no run on them.
Old 03-21-2017, 04:29 AM   #28
Roelof's Avatar
Send a message via ICQ to Roelof
Do you want the hussle to damage the rubber wheel of your starter box, burn up the motors of the starter box, heat up the engine that far until even the tank is melting and other problems you have to face when starting a tight engine ?
Sometimes you do get an engine causing all this but most of the time the 1st start before adding some heat is no problem. So yes, it is a question only you must answer.
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
Old 03-21-2017, 05:58 AM   #29
Melting the tank?? You shouldn't put the entire car in the oven to preheat!
NitroVein is offline   Reply With Quote
Old 03-21-2017, 07:43 AM   #30
Roelof's Avatar
Well, we had once a very tight motor, we heated it up with a paint heating gun but my pitman did not see he was melting the tank as well. But lucky we are not the only ones, we have seen it more often.
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9307 09-20-2017 04:28 PM
New Engine wont start thr49 Nitro On-Road 20 11-21-2014 07:50 AM
3 New Novarossi engines comming out!!!!! MRX4-R03 Onroad Nitro Engine Zone 37 03-08-2007 11:13 PM
new engine woes (novarossi rs12) packetdreamer Nitro On-Road 39 08-07-2004 09:14 AM
