Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
    Hide Wikipost
Old 06-29-2017, 08:50 AM   -   Wikipost
R/C Tech Forums Thread Wiki: The Official BLOK Engines Thread
Last edit by: MattDub
The BLOK engines are based on the OS Engines XZ-B Spec II. Carburetor and carb inserts are the only differences. The 22C carburetor is used on the 21aM and comes with 6.0 and 6.5mm venturi. The 21J is used on the 21aP and comes with 6.5 and 7.0mm venturi.
More info can be found here
BLOK 21aM
BLOK 21aP
Replacement parts
All OS Engines .21 XZ-B Spec II parts will fit the BLOK 21aP and 21aM engines. The only difference being the 21aM uses the 22C carburetor.
A good selection of replacement parts can be found here.
How to set endpoints for maximum fuel economy and drivability.
These engines are very powerful, which IMO is a good thing as it's challenging to modify an engine to produce additional power from what it was designed to without sacrificing durability or longevity. With a little tuning, you get the best of everything, great power, long runtime and a long lasting engine.
We chose our new engines because they're extremely reliable, easy to tune and make incredible power... but wasted power is wasted fuel! What most people don't realize is that with these engines the power can easily be turned down to increase mileage and drivability. Also, engine temps are reduced, and your engine will last longer. When tuned correctly and with correct EPA/clutch settings you should be able to get 10-minute pits easily.
First and foremost, the key to extended run time is to reduce wheel spin. Reducing wheel spin is paramount because if you are increasing throttle and the vehicle is not accelerating, fuel is wasted. Think about it like this, run time is roughly equivalent to mileage and if you're using more fuel to go the same distance, mileage goes down. Run time can be maximized by reducing the throttle end point and/or by adjusting clutch settings or using a different clutch.
Let's work with endpoints first. I recommend starting with the 6mm venturi in a buggy and the 6.5 in a truck unless you are on a very high grip track or need additional power. Set the throttle pull on the bench by using a set of calipers and measuring the distance from the mid needle to the low needle. Wide open throttle (WOT) with a 6.5 mm venturi should be about 61.7 mm or 62.2 mm with a 7.0 venturi. You can also adjust WOT by removing the air filter tube and verifying the slide pulls one point past the venturi at full throttle.
In a truck, we generally keep the EPA at 62.2 mm as trucks generally weigh more and have additional traction due to the larger tires but in a buggy, our engines generate quite a bit of power and can be a little difficult to drive.
For this reason, we recommend turning down the EPA on buggies and we've found the optimal setting when measured from the mid to low needles to be roughly 59.6 mm. Turning down the EPA does two things; it makes the vehicle much easier to drive without sacrificing top end and significantly reduces wheel spin which improves runtime. If you feel that you need additional power, increase the throttle EPA and retune the engine. Typically we only increase the EPA on high traction surfaces or tracks where we need a little more power out of the corner to clear jumps.
Next is the clutch. With the clutch, you can adjust the power delivery and 'feel' of the engine. If you have very good throttle control changing the clutch might not be as important, but with me, this helps a lot. Like I mentioned before, a truck can typically use all the power our engines generate and we recommend an aluminum flywheel, but in a buggy, we usually recommend a steel or heavier flywheel.
A steel flywheel can help provide a more linear feel to the throttle especially on low to medium grip conditions. IMO a steel flywheel is very important and should be used almost everywhere with the 21aM engine in a buggy. If traction is low or you feel that the buggy still has too much power, carbon shoes can also be used to help smooth power delivery.
Print Wikipost
Like Tree21Likes
Old 02-17-2017, 10:26 AM   #16
Hello HaulinBass,
I am sure our dealers and distributors will have them available soon at discouted (coupon) pricing.
Originally Posted by HaulinBass View Post
might want to cool it with personal attacks, so research would be what?
the bore and stroke are identical, its a three port sleeve with allot of exhaust duration and a crank with fairly open timing numbers. Im guessing they went more conservative on the crank timing as the spec2 and 3 are pretty much as far as you want to go on crank timing without having a drag specific motor.
Im not stupid when it comes to motors , show me the internals and I can make a pretty good estimate on what it is and how it performs.
Thank you Jeff for the info on the inserts
Any way to get one of the pre production boxless engines without paying full M.A.P?
Matt Wolter
Tekno RC - National Team Manager
MattDub is offline   Reply With Quote
Old 02-18-2017, 02:16 PM   #17
rcmania74's Avatar
Trader Rating: 55 (98%+)
Originally Posted by Areno View Post
It's a Hara Edition with the Worlds head. Just look at the specs. They changed the carb on the M version. Yes u need to take it apart to figure that out. Fml. Don't be butt SOAR...
it is not a hara edition. Thats a an old vzb...ryan told me yesterday its a spec2....cant get any more or a definitely right answer than that.
1/8 IC Fan likes this.
Scott chilson... ..smac track. ...dirtburners..hrp checkered flag hobbies ...Alpha engines..nitro pro fuel. ...SAVOX SERVOS HOBBYWING ELECTRONICS. ...wanna know why i dont have a perfect trader rating anymore...feel free to ask because i will definitely tell u!!!
rcmania74 is offline   Reply With Quote
Old 02-18-2017, 10:06 PM   #18
It's a spec 2 but has a steel rear bearing (better imho) and the carbs and inserts are different. Cant remember what carb but helps smooth out the power for buggy. Engine is a beast like a spec 2 should be.
Areno is offline   Reply With Quote
Old 02-19-2017, 03:56 AM   #19
offroad dude's Avatar
Trader Rating: 25 (100%+)
Yeah but the Spec II was a gas guzzler.
offroad dude is offline   Reply With Quote
Old 02-19-2017, 06:28 AM   #20
If they found a way to increase the mileage you can put me down for 2
Old 02-19-2017, 01:02 PM   #21
dogwood174's Avatar
Then you should go ahead and get them ordered. I just got mine and I can't wait to test and race them next week down in Fl.
Team Tekno driver, AKA, Futaba, Tekin, Hitec, Bodies by "Fat Joe"
dogwood174 is offline   Reply With Quote
Old 02-20-2017, 07:08 AM   #22
portyansky's Avatar
Trader Rating: 54 (100%+)
Buggy motor with a 2090 and 6mm venturi.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 02-20-2017, 08:20 AM   #23
Mikeand22's Avatar
I believe we had a guy get 11 minutes out of his this weekend.
Mikeand22 is offline   Reply With Quote
Old 02-21-2017, 06:47 PM   #24
Mikeand22's Avatar
Does Tekno have plans to release a pipe as well or just plan to use the OS pipes?
Old 02-22-2017, 02:34 AM   #25
Ilias's Avatar
Hi,
No plans for pipes at this point, most drivers are using the OS 2090 pipe which has been proven to be the best match for our engines.
Tekno RC
www.teknorc.com
Ilias is offline   Reply With Quote
Old 02-23-2017, 05:03 AM   #26
kgombe's Avatar
The Hara Edition was not a VZB.. it was a XZB
Kijana Crichton
kgombe is offline   Reply With Quote
Old 02-23-2017, 01:16 PM   #27
Mikeand22's Avatar
What is Tekno recommending for plugs? With the engine I run right now, I only run that brands hot plug. Would it be the same, but an O.S. plug? Thanks
Old 02-24-2017, 05:25 AM   #28
portyansky's Avatar
OS P3
Team Hitec
Old 02-24-2017, 07:41 AM   #29
brokenmoto's Avatar
New engine working good for Ryan. Nice to see him not flame out while on a charge. Can he dominate DNC?
brokenmoto is offline   Reply With Quote
Old 02-24-2017, 07:53 AM   #30
HaulinBass's Avatar
lutz without motor issues is going to be a force at all the big events this year. if he gets out front early sat I see him checking out.
Frank L and TRUGGYRACER1 like this.
Tyler MacKenzie
Relax, Have fun
SOAR Racing USA/Dialed RC Hobbies
HaulinBass is offline   Reply With Quote
