What NITRO FUEL %
Old 11-11-2016, 12:52 PM
FASTLANE81's Avatar
Default What NITRO FUEL %
Hey guys , I have a ROMA .25 for truggy.
The recommended Nitro % is 25%. for the ROma.
What should I be using 25% , 20% or 30%?
What is your opinions on this?
FASTLANE81 is offline
Old 11-11-2016, 03:50 PM
B3nno810's Avatar
If its recommened to use 25%,i would use that. Either 25% or 30% is fine. Dont run anything lower then 25% though.
B3nno810 is offline
Old 11-11-2016, 05:49 PM
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Best bet as previously stated, stick with manufacturers recomendations. This was the fuel which the motor was designed and tuned for.
1/8 IC Fan is offline
Old 11-11-2016, 06:26 PM
ozziii's Avatar
I reckon the manufacturer would probably know what they are talking about so if they say 25% then thats probably a good start & the best choice.
ozziii is offline
Old 11-12-2016, 04:53 AM
Roelof's Avatar
Why not lower than 25%?
More nitro than recomended can do more harm than a lower content.
It is up to the topicstarter what he is going to do with the engine and what he wants to invest. In the case of racing he needs to keep the rules in mind. If he just want to bash arround and want to save some money 20% is perfect to run.
Roelof is offline
Old 11-12-2016, 05:26 AM
B3nno810's Avatar
OEM clearly states 25% nitro... why run a lower content? For the price difference, just run the recommened amount. You really dont save much if any money by running 20% over 25%. OP clearly states what is recommened by the OEM and asks what grade to run. Also running a lower content than adviced can cause damage...
B3nno810 is offline
Old 11-12-2016, 06:34 AM
Roelof's Avatar
Explain how?
The nitro content also shifts the ignition timing, more nitro makes it sooner what will give more load on the rod, crankpin etc.
But yes even at the advised nitro content you can damage an engine if you do not know how to tune or using a bad fuel.
Over here in Europe we have a 16% rule and many 25% setup engines are running 16% without any issues.
Roelof is offline
Old 11-12-2016, 09:31 AM
Go with what you can get. I know around me there is no such thing as anything less than 30 lol I wouldn't run anything higher but I can personally attest to someone who ran 50% home brew drag fuel through his Roma no problem. Engines are made to handle today's fuels. All of them. That's like a Volkswagen gti that takes regular but performs best on premium fuel. Just get what you can locally in the 11% oil range and have fun.
rotor head33 is offline
Old 11-12-2016, 09:47 AM
FASTLANE81's Avatar
Awsome feedback guys....im probably going to stick with the recommendation of the engine %25. But if I do decide on 30% what would be the Benefit?
Old 11-12-2016, 08:16 PM
B3nno810's Avatar
Explain how?
A lower percentage of nitro also effects ignition, causing your engine to labour harder and also not burn as clean. Causing more strain and stress as youre pushing harder to get the same result.just because it can run it, doesnt mean it should. A performance car works alot better when running a higher octane fuel as opposed to a lower octane. Burns alot more efficiently, cleaner and also causes less stress on components as youre getting a better ignition... go run 98 octane for a week and then drop back to 91, you will notice the difference straight away. As the engine wont run as well on the lower octane fuel.
B3nno810 is offline
Old 11-12-2016, 10:02 PM
Audiobahnaholic's Avatar
Trader Rating: 44 (96%+)
You're argument is invalid. It all depends on compression ratio what runs well. Same with rc
Audiobahnaholic is offline
Old 11-13-2016, 01:03 AM
Roelof's Avatar
Lower nitro content gives a later ignition. The combustion starts further beyond TDC what will lower the load/stress on the components. The amount of powerdifference between 20 and 25% is hardly noticeable.
For the topicstarter, running on 30% will give some extra bottom power, if you can notice it.
Roelof is offline
Old 12-08-2016, 08:20 PM
David Bump's Avatar
Novarossi engines run great on 25% there is no reason to run 30% whatsoever.
You arent going to save money buying nitro less than 25% either. just run good fuel, i personally thing byrons 25%nitro 11% lubrication is the best. Vp has some good fuel as well. Only some crappy hobby shops charge more for higher nitro percentage, if you look online, 20% and up all costs about the same. maybe a dollar or so variance. I remember a hobbytown usa that tried to charge 50$ a gallon for traxxas 30% top fuel, what a joke.
David Bump is offline
Old 12-09-2016, 04:40 AM
TruggyDude91's Avatar
I have always ran 30% nitro in my Novarossi engines with no problems when I use to use them. 30% is more widely available in my area than the other nitro percentages. I would stick to Byrons, Werks, or Bones Brew for fuel as they have the most consistent blends and best oil packages available. For some reason, my Nova engines really liked Byrons Pro Driver 30% with 9% oil. Ran really crisp and strong.
TruggyDude91 is offline
Old 12-09-2016, 06:26 AM
Frank L's Avatar
Trader Rating: 148 (100%+)
All novas reccomend 25%. I have never seen one have an issue on 30%. Personally I like 25% it adds a little bit of runtime and I can't really feel the difference from 30%. Byrons makes it in many oil blends to suit your needs/ tuning ability
Frank L is offline
