Reds Quattro clutch
Old 09-27-2016, 07:14 PM
Trader Rating: 72 (100%+)
Default Reds Quattro clutch
Hi guys, can you run the kyosho clutch bell on the reds clutch? Or do you have to get the reds one?
Is the fit good if the original K one fits?
ok just looked up the reds CB's, they are 20 and 28 bucks. Any other CB's fit?
Tmachine is offline
Old 09-28-2016, 05:28 AM
hyperfuxx's Avatar
Trader Rating: 32 (97%+)
I know the novas fit. They all should fit but you might not be able to get the shim behind the clutch. Mugens there's not enough meat but reds and novas that I know you can run a shim behind.
hyperfuxx is offline
Old 09-28-2016, 09:42 AM
Default thx
thanks, they all fit but the gap is my issue. I want to get the shoes contact patch all on the bell.
So I guess I'm looking for the deeper bells.
Tmachine is offline
Old 09-28-2016, 11:29 AM
hyperfuxx's Avatar
I haven't had any issues with the contact. Never tried a K bell. I'd stick with the reds myself. No issues for sure
Old 09-28-2016, 12:58 PM
Ultimate bells fit.
http://www.ultimaterc.de/articles.ph...cle=1000003319
Peter Dietrich is offline
Old 09-28-2016, 06:39 PM
R/C Tech Elite Member
jkas10's Avatar
Trader Rating: 123 (100%+)
I recommend that you get the REDS DURABELL. The teeth of hat bell will last longer than the clutch shoes, and the shoes last forever! We have run the same bell at Psycho Nitro, AMS, Wicked Weekend (including full practice days at each event) as well as half a dozen club races. Money well spent.
jkas10 is offline
Old 09-29-2016, 09:57 AM
Thanks. I'll try the Reds...
Tmachine is offline
Old 09-30-2016, 06:17 PM
Trader Rating: 61 (94%+)
U want the vented too. Or the clutch will melt down.
tcb22185 is offline
Old 09-30-2016, 08:51 PM
Idk about melt but I do know in super dusty environments mine stays cleaner with the vented bell
rotor head33 is offline
Old 09-30-2016, 09:30 PM
So what kind of use do you expect out of clutch? A gallon?
Tmachine is offline
Old 10-02-2016, 11:30 AM
jkas10's Avatar
The shoes last at least a gallon. You might be able to get a couple gallons pretty easy. I seem to change mine out before they are worn out due to preparing for a long main at a big race, or similar. The DURABELL will go for a good 4+ gallons.
jkas10 is offline
Old 10-02-2016, 11:07 PM
Default Thx
So I am running on a mp9. Have you guys notice that the fit has a 1-2mm gap from the clutch to the front of the motor? To make it fit I have to run it without the washer behind the collet...this is going on a os motor.
Tmachine is offline
