Nitro percentage question ?
I am currently running 25% nitro fuel and am going to switch over to byrons race blend and was wondering would switching over to 30% give any performance gains if not what are the advantages or differences of running a higher nitro content? I've also noticed most fuels drop the castor content down to 9% when the nitro content goes up to 30% can anyone explain why this is common for fuel manufacturers to do this? In what way would 9% effect the engine and/or performance from 11%?
More nitro, regardless of the percent, means more HP. Because stoich for nitro is such a low ratio, it also means more fuel consumption as nitro percentage comes up.
Ok thanks for the input,it sounds like the switch to 30% is the way to go
I run 30% because it keeps the carburetor tune more stable within the wide range of temperatures I experience from day-to-day on the Mid-Atlantic coast. I usually only have to add .1-.2mm of shimming to the cylinder head to compensate for the higher nitro content.
I also add 1% pure castor oil to my Byron's fuel. So technically the fuel has very slightly less than 30% nitro because of that added oil volume, but it's not enough to make a difference in performance. The extra castor oil makes a HUGE difference in engine temperature and longevity, though. I only run RTR engines, the Losi 3.4 and Picco P-0 being my fanciest engines and the rest being HPI, GO, and Traxxas engines, and I used to have to replace the piston and cylinder once a year. This year none of my engines required any service whatsoever, and they're much less prone to temperature spikes from hard running. I've noticed a decrease in darkened oil dumped out of the exhaust pipe after the first break-in bench run, too.
