Skyrc engine heater?
#17
Can I use 4S Lipo with the Skyrc heater?
#18
Its designed for 3s and personally I wouldn't.
As an aside my competition heat unit failed recently (it wasn't that old but failed all the same). My LHS only had the SkyRC unit in stock and I needed a heater that day so I grabbed one thinking I would get another competition heat later but that was more than a year ago and the SkyRC unit has been absolutely fine and for the price point I won't be buying another competition heat to be honest.
#19
I use the Sky rc competetion heater with 4S lipo all the time..
Works great..
Works great..
#21
Are you referring to an adjustable power supply? I use mine off the same 85A power supply I run my chargers and other devices on, the SkyRC heater will only pull what it requires. I can't find an amperage or wattage rating on any of the specifications, but I can't imagine it being more than 10 amps total.
#22
#23
I'd just do some quick trial and error to find the lowest amperage that would allow your heater to function properly (I believe mine gets up to about 150*F). I assume the little controller on the heater will probably take care of regulating the unit to avoid burning up, as my power supply is 85A.
#24
my skyrc burned up, was using a 3s Lipo high voltage, must have been too much juice for it.
