need HELP my Dynamite rc .21 engine
I can't get my Dynamite .21 engine to idle wil start run for 3 to 4 second's then die and if you hit the throttle it dies. Had it running fine back in the fall have not been able to run it this spring
You can't touch the throttle it dies before you pull the trigger and yes it will rev up some of the times then other times it will bog down I'm frustrated and confused
No not the same fuel but a different brand the glow plug is new also
Thanks sorry it took so long for me to respond been a rough week
