Piston/Sleeve sets interchangeable between engines
My question is in the title; can I take a piston, sleeve, and conrod assembly, from two identical engines and swap them between each other without any issues?
The reason I ask is I have a fusion X5L which has a broken conrod and a minor score in the sleeve. I have another X5L coming in the mail which is fully functional, and I'm hoping to just use the piston/sleeve assembly from that one in my original one.
Thanks for the advice guys.
I'll be sure to measure the crank pin.
As for the bearings, they feel as smooth as they were from the factory, but I assume that's because they were replaced about 3 litres before the conrod failure. Should I still be replacing them or would it be OK?
Things get trapped between the rear bearing and the block
