Are there 2 LSN tuning windows?
I have an OS carb.
set the HSN TO 2 1/4 nice and clean
the temperature on the day was about 110 F / 40 C.
set the idle opening to about 1mm
started to rev and let the motor idle.
turned the LSN in until the high idle and subsequent drop disappeared.
turned the idle down. all was good.
problem was when i was racing the car had a rich bog just off idle.
I then went through and leaned out the LSN some more, lowered the idle etc and found a new idle window.
has anyone else experienced this and is there an explanation. thanks.
- Idle raises (can be slight or drastic) after throttle released
- Idle 'pings' after a few seconds, as there is too little fuel in the crankcase for the engine to properly run
- You will hear a stutter (sounds kind of like a hiccup) when you pull the trigger after idling for a little while, as there is not enough fuel in the engine to have a crisp, clean acceleration. If the engine is extremely lean, your engine may even flame out on it's own or when you pull the trigger
There are more than 2 tuning windows for LSN. It's all depends on the idle gap. If you change idle gap you have to retune lsn and now you have a new window not each one is optimum. For fuel economy you should try tune LSN with least possible idle gap (0.6-0.7mm for most engines)
If the bottom is too lean, the idle will be erratic. You also have a chance of flame out at the end of the straight. One indicator is that when carrying your car from point A to point B and dip the nose down, revs go up almost immediately.
When you're not sure, the best thing to do is to tune from rich to lean. Even if that means if your tune is sorta there, but you're not sure which way to turn which needles you can richen hs and ls a few hours. The engine will be obviously rich top and bottom. Then keep leaning the top end needle until the car achieves the top end rpms. The bottom will be rich and it won't pull off well at this point. Once you have the hsn set, work on the bottom. Do a high speed pass down the straight. Let the car for about 8 seconds. Then gun it. The car will stumble. Lean the LSN an hour at a time continuosly repeating unitl it pulls off crisply and with out bogging. Adjust your idle accordingly through out. Then you're done.
