Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Old 08-08-2014, 10:59 AM   #1
Default Meaning of 5+2
I am looking to buy a new engine and some are advertised as 5+2.
Does this mean that it has a total of 7 intake ports or is it 5 intake ports and 2 exhaust ports instead of 1?
AlGio is offline   Reply With Quote
Old 08-08-2014, 11:08 AM   #2
Imbue's Avatar
5 Ports + 2 Bypass Ports
Bypass ports are the ones one the side of the sleeve just below the "normal" ports.
Now, sometimes (very rarely before, never now) manufacturers did that for exhaust, but I havent seen a recent example of it. But the bypass ports is what its referring to. Some manufacturers don't even bother to add that information.
Imbue Motorsports - RaceImbue.com | Like us on Facebook
Imbue is offline   Reply With Quote
Old 08-08-2014, 11:29 AM   #3
Thank You, now that brings up one more question. Do bypass ports function to allow better flow of the fuel from the crankcase to the intake ports or from the crankcase to the cylinder like an intake port?
Old 08-08-2014, 11:49 AM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
Mixture trapped under the piston when going down can take a shortcut into the transfer chanel.
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
Old 08-08-2014, 12:39 PM   #5
A piston for a bypass port motor will have 2 holes in the piston skirt 90 degrees from the wrist pin holes. That's the other part of letting the fuel short cut into the ports.
Vintage R/C'r living in a modern world
Tug Driver is offline   Reply With Quote
Old 08-08-2014, 11:13 PM   #6
^ this.
On top of that this extra port and holes in the piston improves lubrication and life.
SManMTB is offline   Reply With Quote
