"easiest to tune" ENGINES
This is just a question i would like to have answerd by many.
It's just there so many people claiming theirs is easiest.
for e.g "throw a nova carb on it, its the easiest to tune and fixes the problems"
or "once you get used to a o.s carb it's easy" (this last one conflicts itself all the time and see it mentioned often)
Whats everyones thoughts on easiest engine to tune
p.s Price has nothing to do with it. $150 or $600.00 doesnt matter
sorry, engines lol.
FX hands down!
Whats everyones thoughts on easies to tune engine?
just asking for engines, not opinions on my questioning ability.
My thoughts on this is it has to do with how aggressive the timing is.
Higher timing means harder to tune. Lower timing means easier to tune.
Lower timing also gives less top end speed, and more bottom end.
So basicly, the more aggressive engines are harder to tune than the more mellow ones.
Then of course the carburator has something to do with as well, but mostly carburators all sort of work in this day and age, so that plays less of a role once you know how to tune.
For something easy to tune you'd be looking for something like an Alpha F-850 club racer or any other engine with a lower timing. I'm tempted to say Novarossi P5, but the Novarossi glowplugs make for a narrower tuning window since they are colder. Hotter plugs leave a bigger window to keep the engine running, for a beginner.
Basicly manufacturers will make their "budget engines" lower timing, and their expensive engines aggressive timing. A cheap engine is basicly made the same way as an expensive engine anyway, aside from the obvious things like bearings and the more fancy porting on the sleeve. So they're really not spending that much more money on making the expensive ones. They just change the timing a whole lot.
P3 plug Alpha club racer should be way easy to tune. Probably also OS XR-B, etc. Any of the "budget" engines should be similar, 5-port or 3-port low timing etc.
seriously how hard is it to just say "engine XXXXXXXX" done.??? rather then a big type out.
all i asked" what engine do you think is the easiest to tune" dont think its hard to answer
well.. that was a big giant waste of time...
Os speed is the easiest to tune. Why? I tune it correct once and no need to touch the needles ever again until engine is dead.
YOU CAN NOW CLOSE THREAD.
What a jack ass! I thought his explanation was very informative. There is no definitive answer to your question. Everyone has their own personal favorite engine that they think is easy to tune. It boils down to how persistent are you at learning to tune, and which engine do have that "a ha" moment with and figure it out. Good luck shit wipe!
Wow. You are kind of a punk. Don't ask a question and complain about getting more information then your brain can handle cause if that's the case maybe you should get out and learn how different carbs tune on different engines YOURSELF. All engines are different, nova carbs are good for some and hard for others including myself, my o.s. Carbs have never let me down or made my life miserable at the track but I've also had werks Orion engines in my stable that I liked specifically because u make a tune change and you feel the difference where os u might make minor changes but not feel much the Orion's and werks show noticeably whenever you play with tune allowing you to get the engine wherever you want and can handle. I hated the older piccos but supposedly the carb problems have gone away but that's not something I can comment on.
From my experience if you want easy and consistent tuning, then get an Os engine
