Dynamite Blue Thunder "First Run" Nitro Fuel?
Run your engine in on the fuel that you plan to run all the time
Ive done it both ways.
Only reason I used other fuel, Dyno Blue Thunder or Trinity Monster Brew , was because it had a higher oil content. I only used a quart instead of a whole gallon. Usually motors will benefit, how ever slight it may be, from a higher oil content during the first couple of tanks. After that, I use what I normally run, Sidewinder or Byrons.
Have I seen/felt a difference between the 2? Nope. But that's just me.
i don't think you can go wrong using it. I is cheaper than race fuel and has to add protection with the high oil content.
Try Bones Break-in Fuel. You might be pleasantly surprised.
