VZB Speed Cranks?
Yes, all the Vspec cranks are interchangeable. Slight timing differences, coated,filled, weighted etc... between them but they will all work.
There is no VZB spec 2. VZB is the original version which has been discontinued for years. There were only 2 models. The VZB V-spec. And the VZB V-spec speed version (also available for On-road)
If you need VZB parts look into Bullit, Arrow and JQ as they are all VZB models with different names.
All the new OS lines are now XZB and the parts are not interchangeable.
the first speed had the magnesium head... then they did aluminum head... then a spec 2
the spec 2 had a drilled out lightened aluminum head... so i would say they were 3 but the only difference from the al. head and mag head was just the head... sigh i know that sounds wrong
all parts are interchangeable
i think so.... thats why they changed it to the al. heads...
wont work well... different stroke on the engines... so the vzp crank does not have enough throw to get teh proper stroke on the xzb
