Byron's Lube Booster as an After run oil
As the title says. As I use the last of the gmk after run oil, I was just staring at my bottle of Byron's lube booster wondering if that would be a good/safe choice for an after run oil ? Thoughts ?
No, that oil will not be good as afterun oil straight out of the can. It is very thick. My best adice on afterrun is:
When Finished for the day, just stop your enginea and empty the fueltank. The oil in the fuel is enough if you run a good quality fuel.
Dynamite have some blue stuff that is very good if uyou must use ARO.
My favorite is a mix of 20% Castoroil and methanol. Run it through your engine for 30 seconds when engines is still warm.
