tornado s30 VERY hard to pull start
so i posted about this quite some time ago but i just never got to it. the buggy is extremely difficult to pull start. when i originally posted, many people responded that it was the rod/bar that goes into the back of the engine (dont remember exactly what its called) and that made sense, but my question is is that if this IS the problem, how do i fix it? do i grease it? loosen it somehow? any help would be appreciated as always
or if you think its something else feel free to mention that as well
Is it easy to pull start with glow plug removed?
funny you should ask, it IS easy to pull with the glow plug out. what does that mean? it says that if you want to get some of the excess fuel out to take the plug out and pull the cord. when i do that, it pulls no problem what so ever. but when the plug is in, and im actually trying to start it, thats when it becomes very difficult to pull. any help is appreciated, thanks
Loosen the plug 1/4 turn. Once started, tighten it back up.
ya but wouldnt i have to do that every time i start it?
yeah loosen off a little until it starts and then tighten...you may have to do that for a while until the motor loosens up..the piston and sleeve are a taper fit so very tight when new but once you get 6-7 tanks thru it should be easier to start and may not need the glow plug loosened.
ok so i got it all put back together and tried what you guys were suggesting, and what its doing is the pull start is pulling easier, but it will pull once or twice where you can feel it turning the piston, but then it just pulls freely. you pull the string up and you can feel that its not turning anything its just turning freely, what could that be?
ok, ill search for the part and see if that helps. the car is fairly new so it must have been bad from the start. ill give that a go and check back. thanks as always!
you might be flooding the engine too much too. I don't know how much you are priming but too much can make it hard to pull.
