Should I spend the money on the $105 Competition Heat engine heater?
#31
Seems like everyone is forgetting (or just didn't read) that the OP is trying to start/break-in a Traxxas RTR engine.
The Comp Heater and it's clones have their place, but this is NOT one of them. A heat gun or a hair dryer will work fine. TBH, so will not even preheating it.
As for the higher price for our heaters compared to the knock offs. I refuse to have them made over seas. When we first started this business we had parts and pieces made from all over and worked hard to get things done right here. All of our heaters are custom made, Yes, when we get an order they are assembled and each one is tested.
#32
And if you have a high dollar engine and dont have a Comp heater - Get One. I was one of those (complaining about the price) people until I got one last year.. OMGoodness the difference it makes with engines. And my engines are still in excellent shape.
#34
What if I cannot afford the comp? can i use a heat gun? Im only going to be running this in front of my house on my private road and there is an outdoor ac outlet so i dont have to worry about being at a race track or anything
#35
wow! If I were to break it in during the spring when its 70 degrees out, i probably wouldnt preheat it and just start it, let it idle to heat itself up, and then continue the break in procedure. But I am going to break it in close to after Christmas But not if it is below 40 degrees outside
#36
Thank you. I'm glad to get a response from the company of the heater im debating on purchasing. I am going to use my Nitro Sport to learn off of, become more experienced, and become more comfortable with Nitros
#37
The comp heat wouldnt even fit the Traxxas Pro .15 engine I will have. Since the engine isnt a 200 + dollar engine, I wont be too worried because it is only 80 or so dollars to replace
#38
Not trying to high jack your thread, but just a question and hopefully it will give some good guidance and good answers for you and me. I had 2 engines a Ofna .28 and a Novarossi 528 that I heated with a heat gun, As soon as I put them on the bump box and went to start them both locked up with the piston at the top of the sleeve. I sent both to Ray at RayAracing and he took care of both of them. The sleeves were stuck in the block and piston was almost impossible to get out. My question is shouldn't the piston be at BDC before starting after heating. Could some explain maybe what went wrong causing both engines to lock up like that. I got in a hurry and I didn't check piston position. They were used engines I just got with great compression. So I'm sure it was an operator error, that I hope no one else makes.
#39
With a high compression/pinch engine it is wise to heat it up a bit longer and turn back (reversed rotation) the flywheel against its compression/pinch so it has a long turn before it has to face the pinch/compression. With the speed it buitlds up in that half a turn it will start much easier.
#41
I love my Comp Heat!
#43
Would Traxxas Top fuel gum up in my Nitro Sport?
#45
It only gums up if you don't burn all the fuel out of the carb and engine and then let it sit up. I've worked on alot of automotive engines and that's how it works in them. I'm kinda new to the Nitro myself but i've read alot about fuel so this should be pretty accurate facts, If not one of the pro's will post shortly. That's what makes Rctech the best site out there, everyone is always willing to help and there is tons of knowledge on here.
