Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Old 11-16-2012, 11:06 AM   #1
HH
HH's Avatar
Default NEW OS MAX .21XR-B
[IMG][/IMG]
Machine ground fins on the cooling head looks awesome!
It appears O.S. has eliminated the mid-adjustment and gone with a 2-needle carburetor system.
Specifications: O.S. MAX .21 XR-B
Displacement:..... 3.49cc
Bore:................ 16.27mm
Stroke:............. 16.8mm
Practical RPM:.... 4,000~40,000 r.p.m.
Power Output:.... 2.45hp / 33,000 r.p.m.
Weight:............. 370g
compared to..
Specifications: O.S. SPEED .21 XZ-B
Power Output:.... 2.6hp / 34,000 r.p.m.
Weight:............. 355g
Available early 2013...?
KYOSHO MP9 TKI3 | O.S. Speed XZ-B .21 ~ O.S. 2090 | KO Propo RSx
"If it's worth doin'... it's worth doin' it right" - Chip Jett
HH is offline   Reply With Quote
Old 11-16-2012, 03:13 PM   #2
CKmaxx's Avatar
Looks like a budget model....
Tekno NT48.3 and NB48.4 powered by OS Engines
Tekno ET48.3 powered by Tekin
CKmaxx is offline   Reply With Quote
Old 11-16-2012, 05:35 PM   #3
19,950 works out at 245 usd or 192 euros.
Lots of engines at that price range. I think they'll have to sell it cheaper.
Eivind E is offline   Reply With Quote
Old 11-18-2012, 04:40 PM   #4
o.s. was rumored to revert back to the short stroke design.... i guess not. really disappointed in this new design. is that a plastic fuel nipple on a two needle carb? the extra machining on the cooling head edges makes it look cheap and picco-like. and why does it only have one carb retainer? does the screw thread staight into the block instead of the other carb retainer half now?
dont crash, dont break, dont flameout=1st place
tmth3 is offline   Reply With Quote
Old 11-18-2012, 06:41 PM   #5
Rsickles's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to Rsickles
Only one screw on each side holding the block in! Guess you only use two screws to secure the engine too.
Rsickles is offline   Reply With Quote
Old 11-18-2012, 09:28 PM   #6
Paulus's Avatar
This is the new basic model, placed under the XZ-B blue head we will have to wait a bit longer for the new Speed engines.
Teamdriver for: MugenSeiki, MBX7, MBX6-TR, OSspeed engines, Power-Safe-Racing fuel, JVDrc clutches, Sanwa/ Savox electronics.
All the way from the Netherlands :)
Paulus is offline   Reply With Quote
Old 11-18-2012, 09:47 PM   #7
even if you compare it to the base model (blue head) xz-b, it doesnt stack up, .05 less peak power and 8 grams heavier.
SPECIFICATIONS
Stock Number: OSMG2050
Displacement: 0.21 cu in (3.5 cc)
Bore: 0.6 in (16.3 mm)
Stroke: 0.7 in (16.8 mm)
Practical rpm: 4,000-40,000
Output: 2.51 hp @ 33,000 rpm
Weight: 12.52 oz (362 g)
(base xz-b specs)
Old 11-19-2012, 02:51 PM   #8
Trader Rating: 39 (100%+)
SPECIFICATIONS
(base xz-b specs)
It's not supposed to "stack up". It's a low(er) budget engine.
BrakeTurnAccelerate is offline   Reply With Quote
Old 11-19-2012, 03:06 PM   #9
the xz-b blue head is their "budget" engine now. why would they downgrade on an update. so in my eyes, yes it is supposed to stack up. the only thing justifying these lower specs would be fuel consumption, but even then i think i would rather have a little more grunt than 30 seconds more run time. this engine looks like an absolute joke. i like the older v-spec engines. i was hoping this new engine would be a fusion between the vz-b and xz-b
Old 11-19-2012, 04:32 PM   #10
Rsickles's Avatar
I don't think you realize what you are talking about. The regular XZ-B is NOT a 'budget' engine. The 21VG(P) is their 'budget' .21 engine.
Look at the market. For the price of a XZ-B it is competing with the Werks B6, B5 Pro, Alpha Lutz Edition, Alpha A852/A872, Nova Plus 21-4, Nova P5 XLT, RB Fire, Fusion X3, some of the Picco-based engines, GO GXII-5, etc.
The XZ-B is a performance engine, not a budget engine.
Old 11-19-2012, 04:34 PM   #11
$280 for an XZB isn't really "budget", when you figure that there are a ton of engines $200-250 range. The XRB is listed for $245 (as someone posted above) and will likely sell a good bit lower than that, price-wise.
Old 11-19-2012, 05:24 PM   #12
i know exactly what i am talking about! for the typical o.s. consumer(me) the xz-b (blue head) is indeed a budget engine. you are connecting price point with performance. i never said the xz-b wasnt a performer, i said it was a budget engine. the alpha lutz, werks b2, nova p5, picco 5tr, rb f11 are all budget engines, doesnt mean they dont perform. you see what im saying now? let me spell it out. for someone that doesnt mind paying $500 for a quality race engine, $280 is budget. i bought my blue head as a practice/club racing engine. youre comparing engines by price as i bolded above. im comparing them by features and specs. who the hell races 21vg's? are you kidding? thats an rtr/basher grade engine. is that what you're comparing this new xr-b to? an engine that uses standard plugs
Old 11-20-2012, 03:05 PM   #13
Rsickles's Avatar
I'm not comparing this new engine to anything... why? Because who knows how "good" or "bad" it is. The VG was mentioned because it IS the "budget" .21 engine by OS.
In consumer marketing lingo that would be called "value", not "budget". There's a VERY big difference between these two terms.
Are you saying Lutz races a "budget" engine? Are you saying Kortz races a "budget" engine? I think some of these manufacturers would have a bone to pick with you.
I'm sorry but your 'reality' where everyone is driving $500 engine simply isn't true. To say a $280 engine is "budget" is mockery, when that's the bread and butter of .21 engines. Ask anyone of the engine shops on here what level of engines they service/see the most of in their shop... I assure you they aren't $500 engines.
What features and specs have you compared thus far? Looking at a peak HP figure - which is so far off reality and real-world performance?
The only one saying the XR "doesn't stack up" is you... making presumptuous opinions of something that's not even in production. I'm done here.
Old 11-20-2012, 05:55 PM   #14
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Don't count out this engine nothing is spelled out with great details. OS manufacturer great power plants. budget or not it's another mill added into the market more the marrier.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 11-21-2012, 05:25 PM   #15
kman16jr's Avatar
Trader Rating: 53 (100%+)
Why are the o.s. xzb line getting discounted?is this because the worlds edition is around the corner?
Kevin Welfley
AE rc8b3-AE rc8b3e-AE b64d-AE b6d-AE b6
Sponsors:|DDHrc|Team Trinity|Jconcepts|Rc Adiction Products|NitroPro Fuel|M2c racing|Ultimate racing engines|Highest servos|Bellgate Distibutors|
kman16jr is offline   Reply With Quote
NEW OS 21 XZ-B and Speed XZ-B Marcus Falconie Offroad Nitro Engine Forum 5225 07-11-2016 05:24 PM
