Maxy's Cinco BT .21
#46
Thanks for you support.
#47
A friend at the track just got one, probably gunna help him break it in tomorrow. Cant wait to see it run, I basically talked him into getting it because i wanted it so bad.
#48
hi there this engine is very easy to breakin just use the heat gun and fix the 8 carburetor
insert for more fuel and the temp will stay at 200F . with heat cycle method slots of power
realy very nice engine
#53
think he was just referring to breaking in the engine to keep the temps done and make sure you have proper lubrication, its best to use a larger insert.. only for break in..
#54
hi maxy .
kgombe is right thats what i ment after am done with the breakin 6.5 is my goal to get max time and less wheel spinning looking foreword to get anther one
#56
Awesome Engine
Maxy s cinco BT it's the best engine out there. I just race mine last weekend and I just can't wait for it to be completely broken in to see how much run time I will get because I have only put 1/2 a gallon thru it and I am already gettin 8 minutes with a 2072 pipe lots of power all thruout the power band and the most fuel efficient engine I have used. I am very please with my Maxys engine and fuel and like I said it only has a half a gallon so don't be shy with this combo I know Maxys personally and this is the best product available right now at a very competitive price and support.
#59
Has anyone run the Cinco BT Tuned and a Bonito? How do they compare?
