Which Temp Gun?
Which Temp Gun?
I am in the market for a temp gun Is the fastrax one any good because the last one i had was rubbish i bought it from china for 7 dollars.now i need one for my next race on sunday.And the fastrax is available. How is it accuracy is it way off or just a few degrees Or any other temp guns you reccommend?
I have a small fortune invested in engines, so I have no problem spending come coin on THE best temp gun!
http://www.amainhobbies.com/product_...emperature-Gun
I agree having a temp gun is a necessity to make sure you're not overheating, so a good gun is the HPI one on amain.
can even find this one cheaper...look around.......pro quality, though.
http://www.instrumart.com/products/1...ed-thermometer
couple of bad reviews of the HPI gun on a-main...
http://www.amainhobbies.com/product_...acing-Temp-Gun
exergen nuff said! I run elec. and nitro so having a acurate reading for electrics is important as well for my nitros...
http://m.homedepot.com/p/Ryobi-Non-C...ter/100674438/
Checked it against every different one i have seen at the track. Works great, and is very durable....
Exergen is the only one worth having. I own a Raytek and it isn't bad but it's not a Exergen. It's definitely worth having in your tool box. It has many uses and a very important part in your toolbox.
Yeah, honestly spending $250 on a temp gun. I have a hobbyking temp gun. It works great, by no mean am I a cheapo that runs cheap stuff. It works, that's what I want.
I've been using a $10 turnigy....it's been tested alongside a few others (including the one that our local fast guy uses) and it's within 2-3 degrees at 200F.
Again, not to tune by temps, but more to see when my comp heat has warmed up my engine enough, or to see if I went WAY too high or too low on gearing my electrics.
