Nova 4BTT vs OS 21XZ-B
#16
Speeds are factory modded iirc
#17
Both are good, and will do you no wrong.
I currently run a BTT/A and like it very much. I run with speeds and they also run very well. I say go BTT because you can get motor and pipe for price of just speed.
#18
and the truth is both engines rock..
stock vs stock the Speed is more aggressive....it has substantially higher port and crank timing.....driving them both the Speed is more dynamic and powerful.......However the BTT has a better throttle feel in the low end, it has a very tractable powerband that can run a very low clutch stall, which makes extremely good in the tight technical sections of the track..the power delivery is very precise and almost 4 stroke feeling...It is fast enough to keep up on the straights for the most part, but it really shines on rhythm and timing sections of the track....the BTT is a very easy engine to drive fast with..smooth delivery with lots of grunt,
want to see a BTT wake up ? put a JP3 on it.....
some may say the runtimes suffer, however I found with the proper needling the runtimes were on par with all the other pipes we run....
#19
I did also put the 8mm venturi same as my arrow/os.
And it was way more easy to clear any jump in the track.
Just blipp the throttle and jump.
And in this medium/small track i know it was better with the nova.So i guess the bottom in the nova is some stronger.
#20
I stayed clear of the Nova BTT line because of how soft the bottom supposedly was. After watching a few BTT's in action, I'm actually really impressed. Not enough to switch, but I wouldn't say the BTT has any disadvantage over the Speeds. Certainly not a $150 disadvantage.
#21
i didnt know that a speed had port modding done on them my bad.
all I do know is speeds win big races,novarossis win big races....choose one and run it
#23
thank you! I appreciate the support. This is going to be a tough decision. As of now im leaning a little towards the OS. the only thing that kills me is the short time frame of the motor. I just need something that will be there for me on race day lol
#24
Just consider your driving style, both engines are great, if you like to pull the trigger and are a novice like me get the Nova engine to start, after all if you start wouldn't you want to get practice in BEFORE you have to replace it? The Nova lasts longer and is cheaper, both can win a race and sometimes speed kills.
#25
I have ran OS speed engines for 4+ years and I always see 8 strong gallons out of them. Idk why some dont. It could be that the OS engine will run even if the tune is horrible where others will flame. So guys just lean them and burn them up. The OS engine will feel loose quicker but that doesn't mean it's toast it just means its free. The nova may go 10 gallons but by the time 8 gallons rolls around I'm ready for a new engine anyway. I have ran nova engines a while ago and then again recently.
#26
Nova and don't look back!
#27
Thanks again guys. I will be Purchasing the os xz-b and the speed edition. Has anyone bought anything from http://shopping.rcmodel.hk/product_i...sng0bu915kfqq4
#28
PM James he runs the Team Terribles hobby store. He is always competitive and easy to deal with.
Here's a link http://www.rctech.net/forum/private....=newpm&u=63218
